9" two plate centrifugal clutch
japie
Postby japie » Sat Apr 13, 2019 10:23 am
This is my design for a centrifugal clutch used in tractor pulling or drag race up to 2500hp https://drive.google.com/file/d/101b3Xy ... MrP6Nn7DzK
Schermafbeelding 2019-04-13 om 12.08.09.png (228.36 KiB) Viewed 4876 times
japie
piston for PSA DW10 2.0hdi engine
Postby japie » Sat Apr 13, 2019 10:31 am
piston made out off aluminium 7075T6 bore 86,05mm so you can use stock 86mm Ford 2.2tdci pistons rings and end up with the right slot clearance...
https://drive.google.com/file/d/15IQU8W ... SY6dUWkOxU
Used in tiny tractorpulling engine, compression ratio 12,25:1, HX50 turbo 67mm intake wheel boost pressure 600kpa, Bosch type A line pump 650cc/1000injection cycles (800l/h@8Krpm) >600hp@8000rpm
Schermafbeelding 2019-04-13 om 12.18.36.png (235.06 KiB) Viewed 4890 times
And proof that not all designs are that good ;-)
japie
PSA DW10 rods
Postby japie » Sat Apr 13, 2019 10:41 am
aluminium7075 rods for the DW10 engine...
Schermafbeelding 2019-04-13 om 12.31.56.png (180.02 KiB) Viewed 4882 times
they are somewhere inside this pile of parts...
drijfstang.FCStd
(339.34 KiB) Downloaded 58 times
Jee-Bee
Re: 9" two plate centrifugal clutch
Postby Jee-Bee » Sat Apr 13, 2019 10:48 am
Looking good!!
japie
PSA DW10/12 camshaft
Postby japie » Sat Apr 13, 2019 10:53 am
camshaft for the PSA DW10/12 engine, 324 degree intake, 308 degree exhaust, 112 degree LSA, 4mm valve lift at overlap, 11,5mm valve lift fully opened.
https://drive.google.com/file/d/1O1Nyt7 ... 5eLEi5Li7m
Schermafbeelding 2019-04-13 om 12.42.47.png (80.39 KiB) Viewed 4894 times
And what does the high overlap lift when the engine is cold?
enjoying the audience...
Re: piston for PSA DW10 2.0hdi engine
Postby chrisb » Sat Apr 13, 2019 10:57 am
Very impressive, thanks for sharing.
Re: PSA DW10/12 camshaft
Postby chrisb » Sat Apr 13, 2019 3:41 pm
Did you even make the camshaft yourself? Cool!
Would you mind if I put all these posts into one topic? I think it woul be appropriate to have them all together.
japie
Postby japie » Sat Apr 13, 2019 3:44 pm
No problem Chris, I think I am ruining the forum with everything I do... :mrgreen:
Jee-Bee
Postby Jee-Bee » Sat Apr 13, 2019 4:45 pm
No i think not.. You show some great stuff!!
NormandC
Re: PSA DW10 rods
Postby NormandC » Sat Apr 13, 2019 5:17 pm
Edit: question unclear after the merging of multiple topics
Did you manufacture them the rods yourself, or is this a reproduction?
I notice that the FCStd model is in one part, while the real-life rods are in two parts. I suppose that the lost thickness due to the cutting process does not matter? (I know nothing about engines)
