9" two plate centrifugal clutch
Re: 9" two plate centrifugal clutch
japie wrote: Sat Apr 13, 2019 10:23 am ping
I have merged the topics, so we have one nice engine building topic. You should edit the first post and change the subject to something generic describing the machine
Re: PSA DW10 rods
NormandC wrote: Sat Apr 13, 2019 5:17 pm Edit: question unclear after the merging of multiple topics
Sorry, Normand. I still think it is better like this.
NormandC
Post by NormandC »
No problem with me, just wanted to edit my reply to avoid confusion.
japie
Re: PSA DW10 rods
Post by japie »
Did you manufacture them the rods yourself, or is this a reproduction?
I notice that the FCStd model is in one part, while the real-life rods are in two parts. I suppose that the lost thickness due to the cutting process does not matter? (I know nothing about engines)
The first four where made ourselfes, later version where CNC produced by a friend (I am an aluminium welder so we "exchange" skills ;-)
This drawing isn't finished due to production process steps, the 2 parts are screwed together at 60Nm after that the hole is milled else due to internal material tensions it isn't round.
mike_262
Post by mike_262 »
I love the intake plenum after the intercooler. How thick is the aluminum you used there?
Mike
japie
Post by japie »
mike_262 wrote: Sun Apr 14, 2019 11:04 pm I love the intake plenum after the intercooler. How thick is the aluminum you used there?
Mike
All my sheet metal works are 2mm don't draw stuff like that, use cardboard for the base shape and copy those to sheet metal, some hammering, bending and the old English wheel and off you go... ;-)
Sami91
Post by Sami91 »
You have cast the parts or you have lathe??
japie
Post by japie »
Sami91 wrote: Fri Apr 19, 2019 12:34 pm You have cast the parts or you have lathe??
You mean the bellmouth?
On the lathe but not how you think; a piece of tube, brute force, grease, some heat from a torch and a screaming fire alarm :D
abdullah
Post by abdullah »
Amazing!! :D :D :D
Something I would like to do in my next life...
Post by Kunda1 »
japie wrote: Mon Apr 22, 2019 5:19 pm On the lathe but not how you think; a piece of tube, brute force, grease, some heat from a torch and a screaming fire alarm
This is a t-shirt :lol:
