Dining room table and chair furniture - illustration for floor plan
checkoutpsalm8410
Postby checkoutpsalm8410 » Tue Apr 16, 2019 2:34 pm
Large dining room table and chair furniture - illustration for floor plan.
I drew a house and needed furniture to show client scale and so on.
Z= zero for finished floor.
DiningroomTableandChairs.FCStd
Illustration of dining room chairs for scale
(419.83 KiB) Downloaded 8 times
kisolre
Re: Dining room table and chair furniture - illustration for floor plan
Postby kisolre » Tue Apr 16, 2019 4:10 pm
For the curious :)
Postby chrisb » Tue Apr 16, 2019 5:19 pm
Nice velvet cushions.
I have tried to clone a chair, the result was a bit disappointing:
Bildschirmfoto 2019-04-16 um 19.20.48.png (14.94 KiB) Viewed 804 times
kisolre
Postby kisolre » Tue Apr 16, 2019 5:29 pm
Is this why we dont have "Common" feature in PartDesign?
NormandC
Postby NormandC » Fri Apr 19, 2019 2:56 am
Of course there's a common feature in PartDesign.
See PartDesign Boolean
NormandC
Postby NormandC » Fri Apr 19, 2019 3:12 am
I'm assuming you tried to clone the Part container. Contrary to a PartDesign Body, it does not restrict to a single culminating solid, but is simply a container that holds multiple shapes. The chair was built with the Part workbench, so the clone copies all the Part shapes contained in the container. But I guess you already knew that.
A clone of the chair would have worked if its 3 components had been made as PartDesign Bodies.
kisolre
Postby kisolre » Fri Apr 19, 2019 6:44 am
I meant why is not Boolean Intersection (Common) not exposed as a PartDesign substractive feature? Why make another body if a simple pad/revolution/loft/sweep will suffice? I was going to search for explanation or discussion but got a little distracted :)
Postby chrisb » Fri Apr 19, 2019 8:38 am
There are very few use cases, which need the PartDesign booleans; from what I see here in the forum I guess it's in the order 1 out of 1000. That is because the PartDesign features have a builtin boolean operations: Additive features like Pad create a solid and perform a union, subtractive features create a solid and make a cut.
