Probably the most complex thing I've cut so far
Re: Probably the most complex thing I've cut so far
Postby chrisb » Sat May 04, 2019 4:30 pm
Thanks for reporting back and good luck!
Postby Kunda1 » Mon May 06, 2019 8:38 am
Fantastic!
BTW, what do you mean by this?
m0n5t3r wrote:
Thu May 02, 2019 6:24 pm
I placed the bodies in parts hoping that a2plus would import them as separate objects, but nope...
m0n5t3r
Postby m0n5t3r » Mon May 06, 2019 6:02 pm
It was a bit of a naming confusion, really... In A2+ objects are called parts, I wanted to import several bodies as separate parts, thought if I place bodies in part design parts and only make the ones I want visible it would work automagically (I was also glad I found a use for the part design Part thingy, but that's another story)
It didn't work, but following the discussion on github there is now a command in A2+ devel that allows doing something similar to Arch external references (importing a single body from a FreeCAD file), so something good did come out of this eventually :)
uwestoehr
Postby uwestoehr » Tue May 14, 2019 11:36 pm
Hello m0n5t3r, this feature is now available with A2plus version 0.4.21. When using the new button described here:
https://www.freecadweb.org/wiki/A2plus_ ... ng_Started
you can select what body in the selected file should be imported as part.
Postby Kunda1 » Wed May 15, 2019 4:48 am
:+1:
m0n5t3r
Postby m0n5t3r » Wed May 15, 2019 7:30 am
I know, I guess this got lost in the rest of the text :P
[snip]
