Truss tower supporting exhaust gas chimney
DDM
Postby DDM » Fri May 31, 2019 8:18 pm
I tried to reproduce in FreeCad a project designed a couple of years ago with standard 2D cad process.
It's a truss tower supporting an exhaust gas chimney.
The tower has a concrete footing supporting two truss structures. There is a bolt-connection between the two steel parts. The lower steel element is anchored in the footing with anchor bolts.
In FreeCad I used:
1) Arch workbench: lean concrete, footing, gruot, rebars
2) Part workbench: base elements for steel elements (vertical angles, diagonals, transversals, anchor bolts and plates). Massive use of compound to assembly main elements (lower and upper truss structures)
3) Draft workbench: move/copy to position elements in the model, arrays to repeat elements in the space
4) Sheetmetal workbench: to bend light elements to support chimney
5) BIM/Fasteners workbench: bolts connection
I found very useful the macro "HighlightCommon.FCMacro" to execute a clash detecion of the model.
I was unable to create a BOM of the fasteners because the bolts I inserted in compunds/array aren't counted by the tool of the fasteners workbench.
Comments to suggest better procedures are very appreciate,
Thanks, Marco
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
bitacovir
Re: Truss tower supporting exhaust gas chimney
Postby bitacovir » Sat Jun 01, 2019 1:02 am
Very well done!!
A great example of a cross workbenches workflow. This is the real potential of FreeCAD.
I did not know the "HighlightCommon.FCMacro" This macro must be included in the BIM workbench.
::bitacovir::
My Blog
Mini Airflow Tunnel Project
Postby Kunda1 » Sat Jun 01, 2019 11:21 am
@DDM This is awesome! And the explanation/breakdown was appreciated.
Please open a ticket on the fasteners GitHub repo regarding this, if you don't mind?
https://github.com/shaise/FreeCAD_Faste ... is%3Aissue
Edit: I also added a ticket to BIM workbench about the Highlight macro
https://github.com/yorikvanhavre/BIM_Wo ... /issues/23
Edit2: Ticket opened in Fasteners WB
https://github.com/shaise/FreeCAD_FastenersWB/issues/50
bitacovir
Postby bitacovir » Sat Jun 01, 2019 1:53 pm
In many consulting offices that work with BIM, clash detection is part of their service of projects/technical documentation review.
::bitacovir::
My Blog
DDM
Postby DDM » Mon Jun 03, 2019 1:48 pm
Thanks @bitacovir, @Kunda1 for replies
Here the link to HighlightCommon.FCMacro...
https://github.com/FreeCAD/FreeCAD-macr ... er/Utility
Done...
bernd
Postby bernd » Mon Jun 03, 2019 9:22 pm
DDM
Postby DDM » Wed Jun 05, 2019 6:59 am
Hi @Bernd,
I started with flamingo but after a while I came back to part/part_design and draft (arrays) tools because the geometry of the tower was very simple and I could manage the elements with arrays. I started with part elements based on sketches (L70x7, L80x8...) then I cloned the parts, moved on the right position and replicated the clones with the array tool.
For example, for the vertical elements I created the single angle and then I repeated it with polar array around the center of the tower.
I used compound to group main assemblies, then I created arch/structures based on the compounds. At the end I assigned the material to the entire structure. I found compounds very useful to calculate the weight of the main parts of the elements, see attached file from a spreadsheet inserted in techdraw..
I didnt' use the macro_bolts, I will try...
Thanks for suggestion,
Marco
Tower_Survey.pdf
(574.08 KiB) Downloaded 53 times
bernd
Postby bernd » Wed Jun 05, 2019 10:30 am
Would be cool if we could get a real material bill for each cross section ... one day we will ...
Postby Kunda1 » Wed Jun 05, 2019 11:16 am
@DDM Have you seen @thschrader's work on the forum?
Ex. https://forum.freecadweb.org/viewtopic.php?f=24&t=35452
thschrader wrote:
CC thschrader
DDM
Postby DDM » Thu Jun 06, 2019 6:32 am
Yes @kunda1, I studied @thschrader's work and mostly @yorik'developments before starting to design structures in FC and I found their works very usefull...
@Bernd...BOM can be based on the compound that are similar to "assemblies" of the commercial softwares. I am thinking of this procedure (mainly for steel structures):
1) Design the basic parts (part, part design for plates, anchor bolts, for beams and columns using Arch/BIM workbenches)
2) Create stuctures with arch workbench and assign material
3) Group the arch/structures in compounds and assign al label to the compound (CL001 for columns for example).
4) Rename all elements of the compound (CL001_PT001, for a plate in the compound CL001)
5) Count the number of elements in the compound only if is assigned a material to the part (so it is a real part, not a construction part)
6) Check if the compound is in an array o cloned (for example many columns in a projects repeated with an array)
7) Generate the BOM for the compound and for each elements in it considering arrays and cloned objects based on the compound...
What do you think?
