"hello world" basic CNC stop block mill
Erich Schulz
Postby Erich Schulz » Wed Jul 17, 2019 12:20 pm
So this may well be the first thing I try to get my 6040 CNC to mill.
It is a "stop chock" that can be rotated to give either a 15, 25, 35, or 45 mm space. (I will complement these chocks with CAM clamps which should only need to provide 10mm of clamping range.
square2.FCStd
(181.37 KiB) Downloaded 29 times
The model uses a spreadsheet to define the dimensions and test 3 seperate milling strategies. The engoraving operation really needs a tool change (or a bigger font, but this is really just "hello world" so if the bit does not break I shall be happy!
Screenshot from 2019-07-17 22-13-02.png (101.19 KiB) Viewed 1142 times
