Billet Washer
Forthman
Billet Washer
Postby Forthman » Mon Aug 12, 2019 8:53 pm
at the request of Kunda1, I open this post to present my last "small" project : a Billet Washer.
Billets are aluminium alloy bars (ø200mm x 8m long) used in industry to make aluminium profiles.
the purpose of this washer, is to clean the billets stored out before entering the oven to avoid defects during extrusion.
some pictures of the project:
Capture d’écran_2019-08-12_22-38-32.png (101.84 KiB) Viewed 557 times
Capture d’écran_2019-08-12_22-39-42.png (70.37 KiB) Viewed 557 times
Capture d’écran_2019-08-12_22-40-15.png (162.83 KiB) Viewed 557 times
A 400L tank feeds a booster pump (230 PSI)
Water is sprayed through six nozzles
the water turns in a closed circuit.
prefilter plates are arranged in the tank, and a filter before the pump removes the finest particles
Forthman
Re: Billet Washer
Postby Forthman » Mon Aug 12, 2019 9:05 pm
And some pictures :
Laveuse 004.JPG (63.67 KiB) Viewed 551 times
Laveuse 003.JPG (52.01 KiB) Viewed 551 times
Laveuse 005.JPG (47.25 KiB) Viewed 551 times
I wrote above that it was a "small" project ...
In fact, this washer will be part of a larger project which should be released in less than a year. :P
Capture d’écran_2019-08-12_22-33-39.png (91.57 KiB) Viewed 551 times
Capture d’écran_2019-08-12_22-34-15.png (117.74 KiB) Viewed 551 times
user1234
Re: Billet Washer
Postby user1234 » Tue Aug 13, 2019 11:14 am
Very good job!
PrzemoF
Re: Billet Washer
Postby PrzemoF » Tue Aug 13, 2019 12:50 pm
Looks very good! Did you do any drawings as part of the project as well?
