Yet another CNC machine.
OficineRobotica
Postby OficineRobotica » Sun Sep 01, 2019 9:12 am
Hello to all in the forum.
I'm starting this thread because my skills as a Freecad user are not that advanced and getting some constructive criticism is always helpful. Also doing an somewhat advanced model/assembly is good exercise.
The build is , unfortunately, conditioned by components that I already have or that are easy to source here where i live. It would of been really nice to have the budget for some higher quality components but it is what it is.
I started by modeling some components that will later be assembled with one of the many assembly workbench available :lol: .Side note: I just can't wait for asm3 to be made available through the addon manager. The amount of work that developers are putting into the "app::link the big merge" is just mind boggling and it's amazing the time that they dedicate to a free piece of software. A big thank you from my side to all the devs.
Here we go:
Freecad info:
OS: KDE neon User Edition 5.16 (KDE//usr/share/xsessions/plasma)
Version: 0.19.17798 (Git) AppImage
Hash: 7e60631239109c632a8f6cca83f6e7e5502e43a1
Python version: 3.7.3
Qt version: 5.9.7
Locale: Italian/Italy (it_IT)
The nema23 motor.
The nema23 motor holder.
Last edited by OficineRobotica on Sun Sep 01, 2019 9:29 am, edited 1 time in total.
OficineRobotica
Re: Yet another CNC machine.
Postby OficineRobotica » Sun Sep 01, 2019 9:22 am
The sbr20LUU linear bearing.
The flexible Coupling
Postby chrisb » Sun Sep 01, 2019 9:34 am
Nice project. From what I can see from the sketches there is a minor detail: Centering a rectangle is usually done by leaving the sides horizontal/vertical and adding a symmetry constraint on two diagonal corners.
OficineRobotica
Postby OficineRobotica » Sun Sep 01, 2019 9:53 am
Thank you for the tip. Faster to constrain and less constraints to be added.
A simplified model of the aluminum profile used for the structure of the machine.
OficineRobotica
Postby OficineRobotica » Sun Sep 01, 2019 10:57 am
The sbr20 linear rail.
bearing
Postby Kunda1 » Sun Sep 01, 2019 1:33 pm
NIce! Also the dark layout looks gorgeous
OficineRobotica
Postby OficineRobotica » Sun Sep 01, 2019 3:29 pm
Thank you. The dark layout is mostly thanks to Latte's dock dynamic color background(adapts to the focused window theme) and freecad's stylesheet . It's really easy on the eyes and it saves allot of space on a 14 inch laptop screen.
dammerel
Postby dammerel » Mon Sep 02, 2019 10:15 am
Hi
I like the UI theme. Is it avaliable to download?
Andrew
OficineRobotica
Postby OficineRobotica » Mon Sep 02, 2019 3:51 pm
Hi
Andrew
It's not a theme per se , it's just a series of tweaks(I'm not sure if one click layout installation is supported in freecad). I'm on kde so the top bar is Latte dock with global menu. That in itself saves allot of space. I moved the " combined view" on the right side and covered the tree view. The tree view overlaid on the 3d view is glass module from triplus with some slight modifications. The overall dark theme is just the default dark/blue css present in freecad. If you are interested I'll post more details when I get home.
dammerel
Postby dammerel » Tue Sep 03, 2019 8:48 am
That would be great thanks
