Fitting for side channel blower
annoyed
Postby annoyed » Mon Sep 09, 2019 10:55 pm
My first drawing whit 0 conflicts! :D
Took 2 hours, to figure out what dimensions and constants can /can’t use.
Sadly after Pad, errors populated.. but I'll remember time when there aren't any! :D
Reason: Fixed broken IMG link
Re: Fitting for side channel blower
Postby chrisb » Tue Sep 10, 2019 5:28 am
If you can't get it sorted, ask in the Help forum.
bejant
Postby bejant » Sun Sep 15, 2019 1:23 pm
Your screen grab shows that you still have Conflicting Constraints in your Sketch, so you should fix that. Your 83 mm, 32 mm, and 76,16 mm Constraints conflict with one another, you only need two of these three Constraints (I used 83 mm and 32 mm, while the blue Constraint doesn't control the geometry and instead is driven by the geometry). You can make your Sketch much simpler by applying Constraints a bit differently:
20190915-annoyed.FCStd
(13.9 KiB) Downloaded 19 times
OS: Ubuntu 18.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19. (dated 2019-08-21)
Python version: 3.6.8
Qt version: 5.9.5
annoyed
Postby annoyed » Fri Oct 18, 2019 7:42 pm
Absolutely Right, that result calculator also say.. but.. ...I start construct that whit circles, ( it came first on my mind ) so that leads some quite interesting trigonometry...
Source: https://postimg.cc/D8fnCTSG
Reason: Fixed broken image link
