Great! Would like to have a look. Attachment is missing though
Embarrassing
You should find it bellow.
Awesome! So if I understand well you plan to use sketches for walls, and then the user can set properties for each wall individualy(with, height, alignment)? It would be great if we would have a graphical way of changing these options. For example when I select a wall, nodes pop out which allow me to change some of the wall properties. But I know this is easier said than done.
I just check my pull requests in Github and find my 1st PR is around last Aug - after reading online some python tutorial to understand a few lines in Arch WB. With some basic knowledge about Python flow control, I mostly work on geometrical aspect so it is just enough for me atm.
https://github.com/FreeCAD/FreeCAD/pull ... s%3Aclosed
https://github.com/FreeCAD/FreeCAD/pull/1592
Hope you enjoy coding for FC soon !
Wow that is some fast progress
I am interested in improving the 2D output of FreeCAD, with focus on architecture. Some of the things that I would like to work on are:
- explore and try to make a better hatching system for architecture
- work on Draft Dimensions(they already work great, but I would like to add more functionality) more arrow symbols, and also custom arrow symbols, I do not know If you tried Archicad, but I would like to make dimensions in FreeCAD work in a similar way
- 3D and 2D view of the drawing, again similar to Archicad(I am not sure this is necessary in FreeCAD, but I would like to experiment with this)
So I hope I will start coding soon, and maybe we could discuss more about the ideas in regards to architecture in FreeCAD(if that is your field of interest). Perhaps we could create a new thread for this, or if there is a similar thread existing, I would like to check it out.
Good luck with your project, looking forward to seeing the final version
It probably would, Blender is really powerful and I used it a lot before, but I wanted to see what FreeCAD has to offer when it comes to visualization. And honestly I got tired of trying to achieve a perfect lighting or shader
