Hi here i gone show you how to do a Fine Real build of a Impellar
for any critics i am open
Impellar Turbine made in FreeCAD
- pl7i92LCNC
Re: Impellar Turbine made in FreeCAD
I think that an impeller (radial compressor) has 2 stages, even though they are made in 2 part:
- the central "inlet" part is close to an axial propeller, similar to what you have designed
- a radial "exhaust" part, that doesn't appear in your design
- pl7i92LCNC
it's not my part, sorry for the misunderstanding, I got it when searching. I was just curious how you managed to do your impeller, that's how I saw your post.pl7i92LCNC wrote: ↑Wed Oct 09, 2019 3:08 pm can you share your part if it is in FC design
i only got a 200mm 5Axis and not capable of AL it hat a 6mm BALLend bit 80mm long
did you make the g-code with fusion ?
But I don't see how you could machine your part, even with a 5-axis machine.
- pl7i92LCNC
thats why i fear 2
im waiting for a WIN10 PC to deliver
i only got Ubuntu
and Fusion needs win10
to get a Gcode build
i only got Ubuntu
- pl7i92LCNC
here is the NEW Sketch
hope you are fine with that one
a smile for the Construct
One try , seeing the image and assumed dimensions.
- impeller.JPG (133.73 KiB) Viewed 3322 times
