Small single-family house made of foam concrete.
rmavrichev
Re: Small single-family house made of foam concrete.
Postby rmavrichev » Thu Dec 12, 2019 6:05 am
Latest version (reworked)
Project file:
https://github.com/rmavrichev/freecad-p ... e_v4.FCStd
rmavrichev
Postby rmavrichev » Thu Dec 12, 2019 6:06 am
External views:
rmavrichev
Postby rmavrichev » Thu Dec 12, 2019 6:18 am
Zolko wrote:
Wed Dec 11, 2019 10:29 am
In the bathroom, you have water coming from all 4 walls, and sewers going down on 3 walls, that's going to make a lot of plumbing. Especially the toilets are going to be a PITA. Can't you regroup the water supply and sewer needs into a more concentrated region (ideally 1 wall) ? And close to the needs with the kitchen ? Much less hassle to actually build.
There are water and sever pipes going throw for only one external wall. And bathroom with kitchen have common wall.
blue - water input
brown - sever
red - electrical input
rmavrichev
Postby rmavrichev » Tue Dec 17, 2019 1:55 pm
Last update: add roof structures and some minor changes in pipes and sewer
Project file: https://github.com/rmavrichev/freecad-p ... e_v4.FCStd
kwahoo
Postby kwahoo » Sat Dec 21, 2019 7:04 pm
Great work!
I used the VR extension to walk around the house and noticed one thing that bothers me. Space between stairs and a wall is very limited, 470 mm. IMO anything less than 600 mm will uncomfortable.
rmavrichev
Postby rmavrichev » Sat Dec 21, 2019 10:15 pm
Hi kwahoo
I suggest using a folding ladder like this:
So this is not a problem.
bernd
Postby bernd » Sat Jan 04, 2020 9:24 am
What is the model for? For fun, for teaching, for a real project? Will it really be build?
bernd
Postby bernd » Sat Jan 04, 2020 9:36 am
is the foam concrete made on building site or is it intended to use foam concrete bricks? How about the inner walls? What are they made from?
paullee
Postby paullee » Sat Jan 04, 2020 2:57 pm
I read this thread sometime ago, and had been curious what does it mean by 'foam concrete' ?
Aerated concrete ? Reinforced concrete with rebar ?
Thanks.
jeno
Postby jeno » Sun Jan 05, 2020 7:37 am
Thanks.
In the repo is a Ytong D400 mentioned. This is a autoclaved aerated concrete brick. I assume the partition walls are done with D500.
See https://www.ytong.ru/produkty-ytong.php (kyrillic pages!)
cheers
