Elmers Wooden beam engine
un1corn
Postby un1corn » Fri Jan 10, 2020 9:17 am
This was done on FC V0.16 in November 2017. only took a couple of days.
The plans are by JDW Draughting services NZ and can be found here:- http://www.vapeuretmodelesavapeur.com/telechargements5/
WB 1.JPG (96.02 KiB) Viewed 1288 times
WB 2.JPG (86.39 KiB) Viewed 1288 times
WB 3.JPG (48.8 KiB) Viewed 1288 times
WB 6.JPG (184.28 KiB) Viewed 1288 times
fmluizao
Re: Elmers Wooden beam engine
Postby fmluizao » Fri Jan 10, 2020 3:11 pm
Amazing :o
Do you mind to share the model? How did you assembly?
un1corn
Postby un1corn » Sat Jan 11, 2020 1:09 pm
The file of parts for this model is 6MB and so unable to post here, I used Assembly 2 in FC V0.16 and worked from the base up, after having created subassemblies of the Moving, con-rod and valve beams and also the crankshaft.
fmluizao
Postby fmluizao » Mon Jan 13, 2020 11:44 am
No problem. Just curious about how you designed the parts. Did you used PartDesign or Part WB?
un1corn
Postby un1corn » Mon Jan 13, 2020 3:12 pm
The parts were created in Part Design WB with the occasional use of Part WB for primitives, sweep and loft etc. where necessary.
triplus
Postby triplus » Wed Jan 15, 2020 7:19 pm
Looking good.
