Rectangular Hollow Section Calculator - Spreadsheet Workbench
Laurie Hartley
Postby Laurie Hartley » Thu Jan 23, 2020 6:53 am
I knocked this little file up to design rectangular hollow sections for my project because I need Australian Standards which don't seem to be in the BOLTS addon?
I think it works Ok but would be happy to receive feedback.
OS: Windows 8.1
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Rectangular Hollow Sections Spreadsheet.FCStd
(21.28 KiB) Downloaded 31 times
fmluizao
Re: Rectangular Hollow Section Calculator - Spreadsheet Workbench
Postby fmluizao » Thu Jan 23, 2020 10:55 am
I think you could have done with just one pad ;)
(15.31 KiB) Downloaded 13 times
Postby Kunda1 » Thu Jan 23, 2020 1:21 pm
Hi @Laurie Hartley
Do you mind adding screenshots to the OP so users who browse this forum can see what you're sharing (without having to d/l) ?
Thanks!
Laurie Hartley
Postby Laurie Hartley » Fri Jan 24, 2020 5:03 am
Thank you very much fmluizao - simpler is almost always better. I will be using your file from now on :)
Laurie Hartley
Postby Laurie Hartley » Fri Jan 24, 2020 5:27 am
Hi @Laurie Hartley
Thanks!
No problem Kunda1 - here they are (using fmluizao's improved file) :) I think the spreadsheet workbench has terrific potential.
bernd
Postby bernd » Fri Jan 24, 2020 10:42 am
would you make the date available for adding them to BOLTS? Only this file would be needed to extended: https://github.com/boltsparts/BOLTS/blo ... hollow.blt
Postby Kunda1 » Fri Jan 24, 2020 12:18 pm
Thanks, just to clarify, OP means both Original Poster and Original Post. What I asked if you could do was add the screenshots to the Original Post (the first post in the thread) so users see it first thing when the click the thread. Cheers 😉
Laurie Hartley
Postby Laurie Hartley » Sun Jan 26, 2020 9:48 pm
bernd, if you meant the data tables, here is a link to the Australian Tube Mills download page that I got the sizes from.
https://www.austubemills.com.au/en-au/ ... el-hollow/
I am hoping you didn’t mean for me to edit the file because that is way beyond my capabilities :D
bernd
Postby bernd » Mon Jan 27, 2020 9:44 am
how about if we would do it together ...
Would you provide the following three text files for australian profiles. As an example I include some of the european ones. These should be deleted ...
Circular Hollow Sections, wheras D: outside diameter, t: thickness
#type       [  D      t   ]
21.3-2.3:   [  21.3,  2.3 ]
21.3-2.6:   [  21.3,  2.6 ]
Square Hollow Section, whereas b: outside dimension, t: web thickness
#type     [  b    t   ]
40-2.6:   [  40,  2.6 ]
40-3.2:   [  40,  3.2 ]
Rectangular Hollow Section, whereas h: outside dimension height, b: outside dimension width, t: web thickness
#type        [  h    b    t   ]
50-30-2.6:   [  50,  30,  2.6 ]
50-30-3.2:   [  50,  30,  3.2 ]
cheers bernd
Laurie Hartley
Postby Laurie Hartley » Mon Jan 27, 2020 8:43 pm
OK Bernd I will have a go at it. I am quite busy the next few days but will try to get the files back to you next week.
cron
