[ Architecture Masterpiece ] Villa Savoye FC Model
paullee
Postby paullee » Thu Jan 30, 2020 6:51 pm
Hi, I have been modelling this building testing some of the features added. Would somehow stop here without further detailing every part of the building, hope someone would like to refine it :D
Villa Savoye - FC Model
Link to FC Model
[ EDIT ]
To view model nothing more is required.
To edit the model, needs below :
- latest commit with ArchWall OverrideAlign / OverrideWidth
- ArchSketchObject.py to work properly ATM.
https://github.com/paullee0/FreeCAD_SketchArch
Just copy the whole folder into your installation .../src/Mod/... and restart FC.
Screenshot from 2020-01-31 02-20-47.png (222.73 KiB) Viewed 1725 times
Screenshot from 2020-01-31 02-21-13.png (194.96 KiB) Viewed 1725 times
Screenshot from 2020-01-31 02-21-29.png (229.95 KiB) Viewed 1725 times
Screenshot from 2020-01-31 02-21-41.png (228.8 KiB) Viewed 1725 times
Screenshot from 2020-01-31 02-21-47.png (225.43 KiB) Viewed 1725 times
paullee
Re: [ Architecture Masterpiece ] Villa Savoye FC Model
Postby paullee » Thu Jan 30, 2020 6:53 pm
More Screenshots
Screenshot from 2020-01-31 02-21-52.png (236.28 KiB) Viewed 1723 times
Screenshot from 2020-01-31 02-22-09.png (236.32 KiB) Viewed 1723 times
Screenshot from 2020-01-31 02-22-12.png (231.15 KiB) Viewed 1723 times
Screenshot from 2020-01-31 02-33-50.png (400.91 KiB) Viewed 1723 times
Screenshot from 2020-01-31 02-35-33.png (216.28 KiB) Viewed 1723 times
bitacovir
Postby bitacovir » Thu Jan 30, 2020 11:40 pm
Nice model. Well done.
Not sure, but probably this is one of the best high quality 3D model of this building (parametric, bim and all that) available by free.
::bitacovir::
My Blog
Mini Airflow Tunnel Project
paullee
Postby paullee » Fri Jan 31, 2020 1:07 am
Thanks, there are hundreds / thousands of features /details that dxf drawing are not available on internet, but noticeable on photos, that is too tedious to 'visual' measure all and detail in the model.
So, a closer look, you will find it does not match photos , especially for those who like designing details :)
And seems LoD is an issue yet to have an easy solution ?
triplus
Postby triplus » Fri Jan 31, 2020 2:47 am
Impressive!
paullee
Postby paullee » Fri Feb 07, 2020 8:13 pm
Just add more screenshots
Screenshot from 2020-02-08 03-58-17.png (206.91 KiB) Viewed 1024 times
Screenshot from 2020-02-08 04-02-22.png (225.26 KiB) Viewed 1024 times
Screenshot from 2020-01-31 02-20-54.png (236.61 KiB) Viewed 1024 times
Screenshot from 2020-01-31 02-21-21.png (240.54 KiB) Viewed 1024 times
Screenshot from 2020-01-31 02-21-24.png (243.13 KiB) Viewed 1024 times
paullee
Postby paullee » Fri Feb 07, 2020 8:18 pm
Screenshot from 2020-02-08 04-14-59.png (191.47 KiB) Viewed 1023 times
Screenshot from 2020-02-08 04-07-59.png (245.48 KiB) Viewed 1023 times
Screenshot from 2020-02-08 04-05-38.png (253.05 KiB) Viewed 1023 times
Screenshot from 2020-02-08 04-01-33.png (199.18 KiB) Viewed 1023 times
Screenshot from 2020-02-08 04-15-45.png (188.5 KiB) Viewed 1023 times
Postby Kunda1 » Fri Feb 07, 2020 8:49 pm
:heart_eyes:
fc_tofu
Postby fc_tofu » Sat Feb 08, 2020 6:18 pm
Link to FC Model
version: FreeCAD_0.19.19510_x64_LP_12.1.2_PY3QT5-WinVS2015
1. importing file "Villa Savoye_GF_1F_2F.ifc" failed
Report view:
No IfcProject found in the ifc file. Nothing imported
Console view:
>>> import importIFC
>>> importIFC.insert(u"E:/Downloads/ready/Villa Savoye_GF_1F_2F.ifc","Unnamed")
>>> Gui.SendMsgToActiveView("ViewFit")
>>> ### End command Std_Import
2. can open file "Villa Savoye.FCStd" but prompt lots of error msgs
<string>(1)<class 'ModuleNotFoundError'>: No module named 'ArchSketchObject'
BTW, how can file "Villa Savoye.FCStd" be correctly exported to .ifc format? I tried many times, but failed everytime.
Thank you, paulee.
paullee
Postby paullee » Sun Feb 09, 2020 12:21 am
Report view:
Console view:
>>> import importIFC
:) Somehow when I model it up to some point, the ifc file still good opened in IFC++ / BIMServer, but FC no longer open/importing but crashes
I haven't had time to post this in IFC/Draft, Arch & BIM sub-forum, maybe you can help? Or even in Mantis BugTracker ?
My fault, I have indicated in the Arch & BIM forum about this but not this. This is an experimental module (I just start learning Python a few months ago :).
No need to have it just opening the file, but if you want to edit some Sketch which you found is named ArchSketch0XX, you need it. And there is a few unfinished rudimentary GUI tools.
I used Linux Fedora + Appimage .... there are some bugs, not known it is related to your problem.
- I select BldgPart_GF, BldgPart_1F, BldgPart_GF and exporting is ok.
- Seem if i select Building to export, there is nothing (in IFC++, or BIMServer?)...?
