Tatoo needle cartriges open souce workflow
czinehuba
Postby czinehuba » Mon Feb 24, 2020 5:25 pm
Just a quick showcase and thanks to everybody contributing to FreeCAD. Awesome piece of software, combined with blender. :D
KB white cartriges_CAD_02.png (101.88 KiB) Viewed 943 times
KB white cartriges_CAD_01.png (94.11 KiB) Viewed 943 times
Blender preview
KB white blender.png (840.56 KiB) Viewed 943 times
Result
KB white front.png (466.42 KiB) Viewed 943 times
fc_tofu
Re: Tatoo needle cartriges open souce workflow
Postby fc_tofu » Tue Feb 25, 2020 7:17 pm
Wonderful work!
How can you convert FreeCAD model to mesh format?
I find FreeCAD internal mesh exporter cannot export smooth round surfaces.
Postby chrisb » Tue Feb 25, 2020 9:25 pm
In the Mesh design workbench you can choose between different meshers and set the parameters to your liking. Please note that a mesh can not really be smooth it only can appear as such. It has no roundings only triangles which approximate round surfaces.
czinehuba
Postby czinehuba » Wed Feb 26, 2020 8:54 am
Wonderful work!
Yes. Exactly like chrisb is telling. I used the mesh design workbench to generate mesh models to export it blender.
fc_tofu
Postby fc_tofu » Fri Feb 28, 2020 1:48 pm
Wonderful work!
Thank you and chrisb! Could you show me the model's mesh wireframe (all edges in Blender) or FreeCAD screenshot ?
jeno
Postby jeno » Sat Feb 29, 2020 8:03 am
Wonderful work!
The internal mesh exporter refers to the settings in the shape view preferences. See also here. The exported mesh is the result of the tesselated view in the 3D-Window.
If you decrease the values for linear and angular deflection you will get a more dense mesh but also a slower refresh rate for the 3D window in freecad. So choose the figures wisely ;) In any case some post-processing in blender is more or less mandatory.
cheers
