Reverse engineering EV plug
czinehuba
Postby czinehuba » Mon Feb 24, 2020 5:58 pm
As an extension to the the previously shared model.
I try to keep up with the latest development version, but keep a few older appimage files just in case I encounter an error.
I try to adopt and FOSS workflow whenever I can, but sometimes I have to use MS for other CAD software or 3D printing slicer.
OS: Arch Linux (GNOME/gnome)
Version: 0.19.19667 (Git) AppImage
Hash: 97de09ad6f1bc642d1f1e322d07e537c96cdb760
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Describing this particular workflow it's just combination of part design and spreadsheet workbench with a few parameters.
Then tried it on my FFF printer to see it fits, does it require further adjustments to the parameters.
Then printed on SLS printer in Nylon-12
Lessons learned:
- Topo Naming issue (the hard way), had to create datum planes to extrude from or to, but I got it working in the end.
- Coming from other CAD background (Inventor and Fusion360 mainly, but also do Solidworks and SiemensNX) I got used to certain workflows, and sometimes it is hard to loose those habits
- My biggest bugbear currently working with other project is that I can reference values from spreadsheet workbench, but couldn't get it to work with reference other dimensions ie. from different sketches, etc. if anybody can give me hints with that, would be great.
I'll try to answer any further questions if I can.
Reason: Fixed typo on thread title
DeepSOIC
Re: Reverse engineering EV plug
Postby DeepSOIC » Wed Mar 04, 2020 1:37 pm
wow, this fff printout looks awesome! How did you get the overhangs printed so flawlessly? Dissolvable supports?
It's done as "=Sketch008.Constraints.NameOfYourConstraint", NameOfYourConstraint stands for what you type into name field when creating constraints.
You can also reference plain edges, vertices, etc. as "=SomeObject.Shape.Edge15.Length", but it's usually a bad idea because of topological naming issue. It is convenient to explore the available attributes with Py Console: type "App.ActiveDocument.SomeObject.Shape.", and you'll see the list of available attributes ("Edge15"-like attributes are not listed there, but the rest are).
czinehuba
Postby czinehuba » Wed Mar 04, 2020 10:26 pm
Thanks for the tip with referencing other dimensions.
The fff print was done with solid supports in Prusa PETG, on MK3S. Haven't used soluble support.
czinehuba
Postby czinehuba » Sun Mar 15, 2020 4:00 pm
Tried to do how you said, but not having any luck . I'm missing something obvious but can't figure out for the life of me.Tried other ways as well but I can't used it as an other parameter.
Would adjust this file so the extrusion would reference the width from the sketch it would be much appreciated.
test.FCStd
(5.79 KiB) Downloaded 2 times
Screenshot from 2020-03-15 15-51-11.png (249.56 KiB) Viewed 450 times
Screenshot from 2020-03-15 15-50-52.png (303.15 KiB) Viewed 450 times
