[ Architecture Masterpiece ] Carpenter Center Of Visual Arts
paullee
Re: [ Architecture Masterpiece ] Carpenter Center Of Visual Arts
Postby paullee » Sat May 02, 2020 11:18 pm
I flip my old Le Corbusier Guide again and realise it is probably the only Corbu's works in North America (not counting UN).
I wish I had visited there to have a look when I was around :(
A really long long time ago when I visited a corbu's building Milowners', Chandigarh and it is still inspiring ! :D
paullee
Postby paullee » Sat May 09, 2020 9:06 am
sergiobini wrote:
Thu Apr 30, 2020 4:27 pm
Hello, i'v been away for a while from the forum and yesterday i return to give attention to the arch/bim workbanches.. So in the user's showcase i found the model of the Carpenter Center of Visual Arts, and i find that is a very good work and is a good thing to use FreecCad to model Architecture Masterpiece. So i download the model and try to make a quick render in Blender eevee, hope you like. Regards
BTW, how do you do the plant / lawn ? In Blender or photo editing ?
Thanks.
paullee
Postby paullee » Sat May 09, 2020 9:10 am
furti wrote: Ping
See if you have a gap to have at the texture applied here - there are a few objects / face the Texture is not applied, for reason unknown to me :)
Thanks.
https://forum.freecadweb.org/viewtopic. ... 10#p393546
EDIT - Seems stuck at some point then texturing stops...
Texturing objects
Texturing Wall__3F_4.5mH__MASTER
Texturing Wall__4F_4.5mH
Texturing Struct__4F_Slab
Texturing Struct__5F_Slab
Texturing Struct__3F_Slab
Texturing Wall__2F_4.5mH
Texturing Struct__2F_Slab
Texturing Struct__2F_Ramp-1
Texturing Struct__1F_Ramp-1
Texturing Wall__5F_4.5mH
Texturing Stairs__3F
  File "/home/paullee/.FreeCAD/Mod/ArchTextures/texture_config.py", line 272, in onChanged
    self.textureConfig.execute(self.Object)
  File "/home/paullee/.FreeCAD/Mod/ArchTextures/texture_config.py", line 225, in execute
    self.textureManager.textureObjects()
  File "/home/paullee/.FreeCAD/Mod/ArchTextures/texture_manager.py", line 119, in textureObjects
    faceSet = faceset_utils.buildFaceSet(
  File "/home/paullee/.FreeCAD/Mod/ArchTextures/arch_texture_utils/faceset_utils.py", line 487, in buildFaceSet
    faceSet.addFace(faceCoordinates, vertexValues, faceOverrides, transform)
  File "/home/paullee/.FreeCAD/Mod/ArchTextures/arch_texture_utils/faceset_utils.py", line 385, in addFace
    face.finishFace(findOverridesForFace(face, faceOverrides))
  File "/home/paullee/.FreeCAD/Mod/ArchTextures/arch_texture_utils/faceset_utils.py", line 182, in finishFace
    originTriangle = buildTriangle(self.vertices)
  File "/home/paullee/.FreeCAD/Mod/ArchTextures/arch_texture_utils/faceset_utils.py", line 22, in buildTriangle
    e2 = Part.LineSegment(v2, v3)
<class 'Part.OCCError'>: Both points are equal
Screenshot from 2020-05-01 06-32-13.png (856.48 KiB) Viewed 170 times
sergiobini
Postby sergiobini » Fri May 22, 2020 11:07 am
[/quote]
Thanks.
[/quote]
Oh it's all done in Blender.. the grass is a particle system made by myself and the trees ar from botaniq add-on
