Delta 3D Printer
hpbmo
Delta 3D Printer
Postby hpbmo » Sun Mar 22, 2020 9:04 pm
Hi everyone
A few years ago I was looking for a free step viewer and came across freecad. I soon started with small constructions and the thought of a 3D printer was also an issue. So I constructed the first parts with freecad 0.15. A friend printed the parts and soon their own printer was running.
In the meantime I have already done a lot with freecad and also used it at work. Especially for assembly aids.
For fun I have now rebuilt the printer with the current pre version. The individual parts were completely created with PartDesign. The goal was to design a parameterizable printer. With PartDesign, Part for mirroring, Draft for arrays, A2plus and DynamicData, the printer was created after several hours.
And here is the result. The file is a bit large at 7.5 MB. I hope that the screenshots are sufficient.
Printer complete
Delta kpl.png (372.36 KiB) Viewed 719 times
Frame
Delta frame.png (326.26 KiB) Viewed 719 times
Frame with linear rails and bottom plate
Delta linear rails.png (397.17 KiB) Viewed 719 times
Printer head with rods
Delta head an rod.png (518.5 KiB) Viewed 719 times
Calcualtion for z-position z-carriage
Delta carriage calculation.png (494.35 KiB) Viewed 719 times
OS: macOS High Sierra (10.13)
Version: 0.19.19955 (Git)
Hash: fd907d6d9789f71007b8d0177d167f1de82629b8
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: German/Switzerland (de_CH)
Hanspeter
hpbmo
Re: Delta 3D Printer
Postby hpbmo » Mon Mar 23, 2020 7:23 am
Hi
Here some more pictures.
Changing the position in the effector master sketch, moves the the carriages form the three towers. The rods follows the carriage and the effector.
Effector constraints.jpg (35.58 KiB) Viewed 662 times
This construction constraints are use for the calculation for the carraige z-position
Effector Master.jpg (18.25 KiB) Viewed 662 times
Effector Pos1.jpg (16.87 KiB) Viewed 662 times
Effector Pos1 3D.jpg (13.37 KiB) Viewed 662 times
If anyone ist interessted, the files are to big, so you can download here:
https://drive.google.com/open?id=1rU9_U ... IZO_MdTYrQ
One file contains a reduced version. So the calc will be done a little faster ;)
Hanspeter
rmavrichev
Postby rmavrichev » Mon Mar 23, 2020 8:37 am
Awesome! Nice job.
kisolre
Postby kisolre » Mon Mar 23, 2020 9:48 am
Nice job. Thanks for sharing :)
Postby Kunda1 » Mon Mar 23, 2020 2:23 pm
Sweet! Thanks for sharing the files as well!
M.Scott
Postby M.Scott » Fri Apr 03, 2020 10:23 am
Whoa, you did an amazing job.
I normally design and print replacements and upgraded components for my 3D printer by myself, but I've never thought to design an entire printer. Well done!
I usually search for free 3D printable models to download on https://top3dshop.com/3d-model-finder/. Then, I import the model in FreeCAD for any modification. Hope it might help.
