V0.19: Just for fun--Newton's Cradle
ppemawm
Postby ppemawm » Fri May 22, 2020 4:45 pm
If they can do it in Solidworks we can do it in FreeCAD!...https://www.youtube.com/watch?v=d7QLdHGKtOk
I thought it would be fun to see if I could simulate Newton's cradle motion with the Assembly4 (V0.9.3) animator. The following screenshots describe the process:
The PartDesign workbench was used to create each body in-context.
Carbon copies of the assembly master sketch was used to create each body. Local coordinate system "connectors or mates" were then attached to the proper vertices in the master sketch for each body. The master sketch serves as the solver for the assembly. If the dimensions in the master sketch are changed, the assembly will update.
Once assembled, variables were defined for the hanger angle, number of balls in motion, and time.
The hanger angle was used to vary the position of the attachment offset of a selected hanger body link as shown in the above property panel.
This property panel of the variables shows the conditional expression used to approximate the pendulum motion with a sin function for small values of displacement angles.
The Assembly4 animator varies the input and output angle of the hangers for a specified time duration. The accuracy of the motion is only limited by your ingenuity in describing the relations of the variables.
Another conditional can be used to decide what to do if there is one or two balls involved as shown in the property panel expression.
Three or more balls could be done in a similar manner but would require more complex conditional expressions of course. That's where the fun comes in!
OS: Windows 10 (10.0)
Version: 0.19.20887 (Git)
Hash: 42c56d9fef82b484448e3730eb7da69c48fe1374
Python version: 3.6.8
Qt version: 5.12.1
"It is a poor workman who blames his tools..." ;)
schupin
Re: V0.19: Just for fun--Newton's Cradle
Postby schupin » Fri May 22, 2020 6:16 pm
:shock:
Extremely impressive (as usual, but still :o )
Lookid
Postby Lookid » Sat May 23, 2020 9:50 am
Love your posts!!
Master sketch, attach to local coordinates, carbon copies, the same words in each post of yours.
It seems that by understanding these few principles, you can use Assembly4 at full power make a lot of things.
Bold of me to ask, but hey :D : Would it be possible to create a very simplified assembly using these principles, and explaining the thought process in the creation, either with text or with a voice-over? What does what and its purpose, in an ELI5 manner. This would be gold.
Also, I'm not really into the CAD world, but are there (a lot of) things that commercial CAD software can do that FreeCAD can't?
fc_tofu
Postby fc_tofu » Sat May 23, 2020 11:24 am
Quite amazing!
triplus
Postby triplus » Sat May 23, 2020 11:52 am
Nice!
Zolko
Postby Zolko » Sat May 23, 2020 11:59 am
wow .... impressive, thank-you. In the case of 2 balls bouncing, the motion of the 2 balls is not identical: do you actually calculate the physical laws for the motion ?
Aleks
Postby Aleks » Sat May 23, 2020 6:50 pm
Is this a physics simulation?
ppemawm
Postby ppemawm » Sat May 23, 2020 8:06 pm
Thank you all for the kind comments.
Would it be possible to create a very simplified assembly using these principles, and explaining the thought process in the creation, either with text or with a voice-over? What does what and its purpose...
I refer you to one of zolko's excellent tutorials: https://github.com/Zolko-123/FreeCAD_Ex ... /README.md
and sjgallagher2's master sketch tutorial: https://forum.freecadweb.org/viewtopic. ... 51#p369748
No. Pendulum motion is nonlinear. However, the displacement angle as a function of time is approximately related to the cosine of the angle from vertical for small displacements (<20 deg). I am using a sinusoidal change in time to simulate the motion for this demonstration.
This is only an example to show the potential of using expressions, attachment offset, and the animator. It is the simplest of the simple. There is no physical collision detection other than the conditional statement.
Note that the angle is being incremented by (5) in this simulation. I suspect the delay is caused by the sequential execution of the animator. If you make the increment smaller the delay is less.
Aleks
Postby Aleks » Sun May 24, 2020 7:48 am
I love using expressions and a spreadsheet. It allows me to quickly prototype some more complex model without writing anything in python. Love your work.Keep it up!
