Case for the BigTreeTech TFT24 touchscreen on 2020 aluminium extrusion
PistonPin
Post by PistonPin »
I'm currently building a small desktop 3d-printer to accompany the larger workhorse. Both printers use aluminium extrusion profiles for their frames; the larger one 2040 and the smaller one 2020 extrusions, and both printers use the same make and model TFT display, a BigTreeTech TFT24 touchscreen. When I designed the case for said display for the workhorse, I sacrificed access to the USB port for a "cleaner" mounting solution, since I was going to manage it with OctoPrint anyways, and access to the SD-card slot was good enough for an "emergency". But now that there will be a smaller and more mobile 3d-printer (where I may not always have the convenience of a Raspberry Pi with OctoPrint), I sat down and designed a new case with access to both, the SD-card slot and the USB port.
If anyone is interested, I've uploaded the files to GitLab: https://gitlab.com/PistonPin/case-for-t ... -extrusion
The design process was quite simple: I started by recreating a simplified version of the display, using the drawings from BTT's GitHub repository for reference and filled in the missing dimensions by measuring them on my display.
I then created a second body, used the shape binder to reference the display, created a datum plane on the thickest part (the body of the rotary encoder), created a box shape, used the "Make a thick solid" tool and proceeded to add and subtract features.
OS: macOS High Sierra (10.13)
Version: 0.19.19667 (Git)
Hash: 97de09ad6f1bc642d1f1e322d07e537c96cdb760
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
bitacovir
Re: Case for the BigTreeTech TFT24 touchscreen on 2020 aluminium extrusion
Post by bitacovir »
It looks cool!
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
PistonPin
Post by PistonPin »
bitacovir wrote: Tue Aug 18, 2020 3:46 pm It looks cool!
Thanks!
paullee
Post by paullee »
Yes, really cool 8-)
Post by Kunda1 »
Fantastic! can we see it operational?
PistonPin
Post by PistonPin »
paullee wrote: Wed Aug 19, 2020 12:44 am Yes, really cool 8-)
Thanks a lot! :D
Kunda1 wrote: Wed Aug 19, 2020 2:52 pm Fantastic! can we see it operational?
Thanks! - Operational? Do you mean the small printer?
Post by Kunda1 »
PistonPin wrote: Thu Aug 20, 2020 10:38 am Thanks! - Operational? Do you mean the small printer?
I guess. How many printers are there ?
PistonPin
Post by PistonPin »
Kunda1 wrote: Thu Aug 20, 2020 12:26 pm
One and a bit. :lol: The bigger printer (yellow parts; in the picture) will get a major overhaul in the near future, but is operational. The smaller one is just an 80% finished frame with a display attached to it. This will still take some time.
