Originally designed for 1:7 scale (1400mm wingspan), but very easy may be scaled to any size using DraftClone tool
I think that 1:10 (980mm) version will come first because I need airplane in this scale for FPV air combat (
https://www.youtube.com/channel/UChmk02 ... WxCNsKCMPw )
Mostly it done by stretching surfaces (Surface workbench) between sketches, in short.
Very often used operation - Part - Slice apart. Also usefull - Draft Upgrade / Draft Downgrade, Curves Join edges in BSpline.
In long story, there are number of "shell reconstuction" was done. For example for vertical stabilizer. Orignally VStab was designed using Curved Shapes workbench, but then leading edge was reconctructed using skeches and Sufrace.
Additional care was taken for trailing edges. Wing, wing fairing, elevator and rudder have cutted trailing edges.
Because this is a Shell, it have zero thickness. This is good for 3D printing in general and allow your to use not only 3D printing, but other materials like foam (using foam cutter). When you have only external walls (shell), you able to make any internal structure for any construction method.
Also, there is no way to make so complex design as solid body in FreeCAD because lot of bugs
PS: Time to time you need to export / import parts (Im using STEP format) with losing history to keep project size small and avoid bugs.
