I've started to model a Focke-Wulf 190-A8 at 1/10th scale, to make an RC plane with it. The fuselage is supposed to be 3D-printed, while the wings should be made with classic wood structure, laser-cut if possible.
First, I imported into Inkscape various drawings of scale models, scaled them to the correct size, and superimposed them in layers. This is not as trivial as it sounds because the drawings, supposedly of scale RC models, differ quite some. I then drew the outlines of the side-view, cockpit cut-out, fuselage frames ...
... exported these as SVG file, and imported it, as-is, into FreeCAD:
I then created different Part containers in a new document, and copied the imported paths into them. Then, I moved the Parts containing the imported paths to their correct location:
Now, I more-or-less have a wire-frame of the FW190 fuselage. So ... what's next ?
