my 1st TechDraw try
y1n
my 1st TechDraw try
Postby y1n » Wed Nov 18, 2020 7:32 pm
with help from macdroid53 and blitzkraft
Screenshot at 2020-11-18 20-24-44.png (250.38 KiB) Viewed 980 times
small-box-drawing.pdf
(307.83 KiB) Downloaded 23 times
https://www.youtube.com/channel/UCMkG-b7WRf2aGSpfvp_GYwg
https://github.com/y1n-dev
openBrain
Re: my 1st TechDraw try
Postby openBrain » Wed Nov 18, 2020 8:06 pm
A bit strange that holes are same size in both parts, considering you'll probably use self-tapping screws or so. Nice work so far. ;)
y1n
Postby y1n » Wed Nov 18, 2020 8:24 pm
Thank you, you're right it's a bit strange :> but I did it just for practicing, so let's tell it will get riveted :)
luberna
Postby luberna » Thu Nov 19, 2020 12:02 am
Hi y1n.
I would like make a 2D draw-tech in freecad, I never did it, allways work in 3D.
I must import the 2D-draw from other program like Inkscape or LibreCAD or can I make it in Freecad?
Thank you in advance for any tip.
y1n
Postby y1n » Thu Nov 19, 2020 1:43 am
..I would like make a 2D draw-tech in freecad, I never did it, allways work in 3D.
I must import the 2D-draw from other program like Inkscape or LibreCAD or can I make it in Freecad?..
hi luberna,
I did this only in FreeCad by using the TechDraw Workbench, the 2D-Drawing is (half) auto-generated from an 3D Object which I created in the PART-Workbench. Take a look here https://wiki.freecadweb.org/TechDraw_Module (at the end of the page are some Tutorials)
all the best to you
luberna
Postby luberna » Mon Nov 23, 2020 1:52 pm
The page is very helpful y1n.
Thank you very much.
