1 floor house for my family
rmavrichev
Re: 1 floor house for my family
Postby rmavrichev » Mon Nov 30, 2020 9:57 pm
ragohix769 wrote:
Mon Nov 30, 2020 8:12 am
Great work, congratulation.
What's your workflow to model the wooden roof ?
Very interesting.
I use part workbench for boolean operations with massives of arch structures. Like intersections, cut and so on.
rmavrichev
Postby rmavrichev » Fri Dec 04, 2020 8:33 am
Extended version upladed to Github.
https://github.com/rmavrichev/freecad-p ... %20inside)
paullee
Postby paullee » Fri Dec 04, 2020 9:10 am
Great model !
How do you do the area calculation ? Automatic ?
Thanks.
rmavrichev
Postby rmavrichev » Fri Dec 04, 2020 9:26 am
Great model !
Thanks.
No, by hand... May be there are exist more effective way, but I dont know how(((
paullee
Postby paullee » Fri Dec 04, 2020 12:00 pm
A few ways, simplest one is Draw a close DWire of the outline of the room, you have the area in the object
rmavrichev
Postby rmavrichev » Fri Dec 04, 2020 12:44 pm
I will try. Thx.
rmavrichev
Postby rmavrichev » Fri Dec 04, 2020 2:45 pm
DWire object does not have "Area" property, only "Lenght"...
So it`s works only with rectangles, by multiplication length and height values from object properties with spreadsheet. At least, in 0.18.4
OS: Ubuntu 20.04.1 LTS
Version: 0.18.4.
Python version: 3.8.2
Qt version: 5.12.8
Coin version: 4.0.0
Locale: Russian/Russia (ru_RU)
balrobs
Postby balrobs » Fri Dec 04, 2020 3:22 pm
Hi @rmavrichev,
can't you use a draft wire as in the example below?
Kind regards
Area_With_Draft_Wire.FCStd
(23.58 KiB) Downloaded 3 times
Edit: Forgot to say that I'm on
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 53eb15fe50306294551f7a5fffcab218b7a4d13b
Python version: 3.8.5
Qt version: 5.12.8
Coin version: 4.0.0
rmavrichev
Postby rmavrichev » Fri Dec 04, 2020 4:52 pm
0.19 version feature...
0.18.4 only "Lenght":
balrobs
Postby balrobs » Fri Dec 04, 2020 5:09 pm
Thanks for pointing it out!
