My Drawings
kisolre
Re: My Drawings
Postby kisolre » Thu Dec 10, 2020 7:02 pm
I just noted the Solvespace screenshots. Did you also use the dev version there?
mhalil
Re: My Drawings
Postby mhalil » Thu Dec 10, 2020 8:07 pm
Yes I am using dev version of SolveSpace (v 3.0-bdd2be60).
Open Source Fan
mhalil
Re: My Drawings
Postby mhalil » Fri Dec 11, 2020 4:15 pm
Part No 49
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-49-1
Part No 55
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-55-1
Part No 57
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-57-1
Part No 58
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-58-1
Part No 59
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-59-1
Part No 61
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-61-1
Part No 62
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-62-1
Part No 63
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-63-1
Open Source Fan
mhalil
Re: My Drawings
Postby mhalil » Sun Dec 13, 2020 6:14 pm
Part No 65
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-65-1
Egzersiz No 742
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-742-1
Egzersiz No 755
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-755-1
Egzersiz No 756
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-756-1
Egzersiz No 762
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-762-1
Egzersiz No 960
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-960-1
Egzersiz No 873
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-873-1
Egzersiz No 931
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-931-1
Egzersiz No 972
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-972-1
Egzersiz No 977
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-977-1
Kül Tablası
Download (.FCStd, .STL) File: https://grabcad.com/library/kul-tablasi-2
Açık Ağız Anahtar
Download (.FCStd, .STL) File: https://grabcad.com/library/acik-agiz-anahtar-2
Open Source Fan
thschrader
Re: My Drawings
Postby thschrader » Sun Dec 13, 2020 8:31 pm
Man, awesome work.
I like your renderings.
Why do you use FC/solvespace parallel (I have no idea what solvespace is, sorry...)
kisolre
Re: My Drawings
Postby kisolre » Sun Dec 13, 2020 10:51 pm
fmluizao
Re: My Drawings
Postby fmluizao » Mon Dec 14, 2020 11:52 am
Amazing showcase :)
A little question... How do you export to XHTML?
mhalil
Re: My Drawings
Postby mhalil » Mon Dec 14, 2020 1:41 pm
Man, awesome work.
Hi thanks.
I want to try and learn many open source CAD software.
SolveSpace is a very capable and extremely easy to use software.
Moreover, the file size is quite small.
Amazing showcase :)
Thanks.
I export the models in XHTML format so that users who do not have CAD software on their computers can view the models.
You can Export your model to XHTML like this;
1 - Select your model
2- Run Export command ( File > Export...) shortcut CTRL + E
3- Select XHTML type from "Files of Type" List
and Save it.
Open Source Fan
fmluizao
Re: My Drawings
Postby fmluizao » Mon Dec 14, 2020 2:25 pm
Never noticed that option in export dialog :oops:
Thanks!
mhalil
Re: My Drawings
Postby mhalil » Mon Dec 14, 2020 2:40 pm
Thanks!
You're welcome
Open Source Fan
