Snowman Cookie Cutter!
zxs547
Postby zxs547 » Thu Dec 24, 2020 4:19 pm
I made a simple, but effective snowman cookie cutter. However, I ran into some problems. I started this project knowing the exact dimensions for the size of my cookies. So, I started with a sketch for my cookie. I then built the cookie cutter around it. Sadly, when I then removed the cookie from the design, my cookie cutter fell apart, as it was bound to the cookie, which had suddenly disappeared. A good lesson that if you are going to bind an entire part to external geometry, you need to make sure not to change that external geometry, as this could cause many problems with your sketch. I've also attached the file if any of you want the cookie cutter for yourselves/family :).
snowman.FCStd
(145.01 KiB) Downloaded 42 times
