First step with FEM
doul
Re: First step with FEM
Postby doul » Sun Jan 24, 2021 7:14 pm
Kunda1 wrote:
Sun Jan 24, 2021 1:26 pm
doul, very cool.
BTW, please remove your version info from your signature.
No problem, it's done.
Also, do you know any folks in the *BSD world that are running v0.19 natively ?
As far I know : no, before the virtual way I try to compile FreeCAD from sources, I failed. After some web searching I saw many "small" modification have to be done. In FreeBSD this job is made by the port maintainer, that requires time and programming knowledge.
FreeCAD is cool 8-)
doul
Postby doul » Mon Feb 08, 2021 9:49 pm
Try the power of external mesher : gmsh
It's a 6061 aluminium tube, 4000N load in center, 6m range.
Design in FreeCAD -> export in brep format to gmsh
- change mesh options (size min/max, MechAdapt for 2D algorithm)
- mesh 2D
- recombine 2D (triangles -> quadrangle)
- set order 2
- mesh 3D
- save mesh and export in inp format -> import in FreeCAD, just drag'n drop in analysis and go on as usual.
tube.FCStd
(755.61 KiB) Downloaded 5 times
FreeCAD is cool 8-)
