First step with FEM
doul
First step with FEM
Post by doul »
Hello !
After some issues with linux mint (why ????), Fem work well fine on debian.
I just want to say thanks to all people for that great CAD, for free 8-) FreeCAD helps me on my all day welding and machining work.
Capture d’écran_2020-12-25_17-26-08.png (268.78 KiB) Viewed 2461 times
carpe.FCStd
(323.13 KiB) Downloaded 89 times
FreeCAD is cool 8-)
Re: First step with FEM
Post by Kunda1 »
doul
Post by doul »
More steps with FEM : a heavy loaded weldable half clamp (screw M30 10.9), with 1500 MPa max stress high strength steel is highly advised !
2 analysis in 1 file, on left max stress , on right displacement.
C3_0.FCStd
(90.26 KiB) Downloaded 44 times
FreeCAD is cool 8-)
doul
Post by doul »
Little flange for cap fixing, before analysis I think C45 steel can do this job, with max stress = 521 MPa, C45 yield strength (Re=450 MPa) is not suitable.
bride_iveco_0.FCStd
(1022.7 KiB) Downloaded 53 times
FreeCAD is cool 8-)
thschrader
Post by thschrader »
Nice work!
BTW: when I have local peak stresses exceeding sigma-max, I run a plastic
analysis by using the additional material-nonlinear option.
Post by Kunda1 »
doul wrote: Fri Dec 25, 2020 4:54 pm After some issues with linux mint (why ????), Fem work well fine on debian.
doul, update to v0.19_pre per the FEM subforum advisory
https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
You can use the PPA or use the AppImage
johnwang
Post by johnwang »
thschrader wrote: Sat Jan 23, 2021 9:05 am Nice work!
What you look at then?
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
doul
Post by doul »
Thanks for the tip ;) I'll take a look.
FreeCAD is cool 8-)
doul
Post by doul »
Kunda1 wrote: Sat Jan 23, 2021 1:24 pm
Okay, it's done now. I've moved to FreeBSD 12.2 since first post, "stable" version is 18.5 now. To get FreeCAD 0.19 running I've installed Linux Debian on a virtual machine.
On left screen FreeBSD running TWM widow manager running Virtualbox -> on right screen Linux Debian 10 running XFCE widow manager runnig FreeCAD. Complicated ! :shock:
FreeCAD is cool 8-)
Post by Kunda1 »
doul, very cool. BTW, please remove your version info from your signature. Since that is a moving target your older posts won't make sense anymore. Therefore we have a guideline to prevent this misunderstanding. Thank you for your comprehension.
Also, do you know any folks in the *BSD world that are running v0.19 natively ?
