Sketcher as kinetic amination, ruled by GUI
doul
Postby doul » Fri Dec 25, 2020 11:46 pm
hello !
Just an other use of sketcher making kinetics animation, ruled with a GUI slider.
I start from https://wiki.freecadweb.org/PySide_Inte ... xamples/fr
Howto :arrow:
- open FCStd file
- enter stekcher, edit sketch
- in python console type : execfile("/home/doul/menu2.py") <with your own file path>
- slide the slider !
Capture d’écran_2020-12-26_00-21-14.png (212.25 KiB) Viewed 744 times
menu2.py
(3.25 KiB) Downloaded 19 times
echelle_casse_iveco_v2.FCStd
(5.05 KiB) Downloaded 13 times
FreeBSD 12.2
kisolre
Re: Sketcher as kinetic amination, ruled by GUI
Postby kisolre » Sat Dec 26, 2020 11:00 am
Cant test right now but shouldnt the sketch be fully constrained? In the screenshot it is not green.
doul
Postby doul » Sat Dec 26, 2020 1:02 pm
Works for me without fully constrained sketch. The slider just rule a constraint among other, like drawn manually.
FreeBSD 12.2
kisolre
Postby kisolre » Sat Dec 26, 2020 4:02 pm
After checking the sketch, you have 1 DOF which is the relative position piston/cylinder. As it should be :)
Please edit the subject of your first post to fix the typo - aNiMation instead of aMiNation.
Jee-Bee
Postby Jee-Bee » Mon Dec 28, 2020 10:48 pm
abdullah wrote:
Sat Oct 31, 2020 8:26 am
something for you
doul
Postby doul » Mon Dec 28, 2020 11:34 pm
More serious project : truck hook lift simulation.
https://duckduckgo.com/?q=hook+lift+sys ... &ia=images
left blue line is a hydraulic cylinder, right blue lines are dump body, center green hook lift system
I loaded file "hook_lift.py" with macro menu.
This simulation helps me get sized all arms, check cylinder stroke and dump body max load angle 8-)
hook_lift.py
(10.27 KiB) Downloaded 7 times
polybenne0.1.FCStd
(4.4 KiB) Downloaded 5 times
FreeBSD 12.2
