New project : 5-axis CNC hotwire foam cutter running GRBL
HardRock
Postby HardRock » Sun Feb 07, 2021 8:35 am
As mentioned in https://forum.freecadweb.org/viewtopic.php?f=24, most parts should be made from foam using hotwire foam cutter, so I need to make cutter first.
Coz we have FreeCAD and construction profile, this is not a problem :lol:
This machine will run under Grbl-Mega-5X with patches that I plan to do. GCODE generation software will be mine.
Hardware controller - MKS Gen 1.4 board.
Now all mechanical parts assembled. All axis running well without any backlash and locks. Also i have done test cut. Wire tensioner works well even on hot wire.
Next I need to screw controller board and power supply, and need to make "cable-management". Also table shoul be instaled, as well as acrylic case because cutter will have closed case and ventilation to make able usage at home.
As i said, GCODE generation will be made with new software, there are two variats:
1. Standalone generator
2. FreeCAD addon (workbench)
Second way is better in my opinion, but first much simpler for me because I'm not familar with FreeCAD internals and addon development.
I think i will ask some questions in development forum later.
bitacovir
Re: New project : 5-axis CNC hotwire foam cutter running GRBL
Postby bitacovir » Sun Feb 07, 2021 7:27 pm
Very nice project!
Thanks for showing it.
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
RDA
Postby RDA » Sun Feb 07, 2021 9:20 pm
Cool, maybe check out the Path WB and contributing to that before making a new one?
ebrahim raeyat
Postby ebrahim raeyat » Sun Feb 07, 2021 10:56 pm
it is interesting.
HardRock
Postby HardRock » Mon Feb 08, 2021 7:05 am
Maybe) i think that it may be hard / long to add hot wire mode into PathWB because workflow completely different from milling machine workflow.
kisolre
Postby kisolre » Mon Feb 08, 2021 7:17 am
I just wrapped my head about how this actually works. And if I understand correctly you have a piece of foam, fix it on the table somehow then trace a contour with the hotwire around it, rotate the piece N degrees, trace next contour. I suppose Path is good at tracing contours and generating them also so why not reuse that? As always it is up to you to use whatever you feel comfortable with :)
By the way how is the extra cut foam removed? Because if it works as I understand it it will fall down and probably cause issues...
HardRock
Postby HardRock » Mon Feb 08, 2021 7:44 am
Algo is really simple. Assume that "build volume" of your foam cutter is a cube. Two opposite faces is a planes where hotwire ends moves - "working planes"
You placing piece of foam inside build volume - it will be "foam volume". Your part should be somewhere inside foam volume.
You need to split two opposite faces of your part into same number of points. More points - more accuracy. Lets take a pair of points, one from first face, and one from second one. Now draw line in 3D space through this points and extend it to cross working planes of build volume. Point of intersection will be coordinate for machine, i.e. position to use in GCODE. Repeat for each pair of points and it will give you a path for GCODE.
For 5-axis foam cutter there is an additional step to make precise side faces for your part.
Rotate part (using rotary table) to +-90 degrees and generate path to cut part by side projection of faces that was splitted into points before.
Also for 5-axis there are ability to use rotary table to decrease axes runout, it will make possible to cut big angles in small build volume by rotating part instead of moving X axis to far.
Take a look into sample project.
I don't know how to extend wire, but main concept should be clear.
hotwire.FCStd
(211.96 KiB) Downloaded 16 times
HardRock
Postby HardRock » Mon Feb 08, 2021 1:47 pm
Thanks to Bance (https://forum.freecadweb.org/viewtopic.php?f=3&t=55345), who advices me to use datum plane / datum line / datum point.
Here is a simple test macro to make path for 4 axis.
import FreeCAD, Draft
doc = FreeCAD.activeDocument()
profile_1 = doc.getObjectsByLabel('profile_1')[0]
profile_2 = doc.getObjectsByLabel('profile_2')[0]
body = doc.getObjectsByLabel('Body')[0]
wp_1  = doc.getObjectsByLabel('WP1')[0]
wp_2  = doc.getObjectsByLabel('WP2')[0]
points_1 = []
points_2 = []
points = [[], []]
for i in range(len(profile_1.Points)):
  line = body.newObject('PartDesign::Line','DatumLine_' + str(i))
  line.MapMode          = 'TwoPointLine'
  line.Support          = [(profile_1, 'Vertex' + str(i + 1)), (profile_2,  'Vertex' + str(i + 1))]
  line.MapPathParameter = 0
  line.MapReversed      = False
  line.AttachmentOffset = App.Placement(App.Vector(0.0000000000, 0.0000000000, 0.0000000000),  App.Rotation(0.0000000000, 0.0000000000, 0.0000000000))
  line.Visibility       = False
  # - Create point on first working plane
  point_1 = body.newObject('PartDesign::Point', 'DatumPoint')
  point_1.AttachmentOffset  = App.Placement(App.Vector(0.0000000000, 0.0000000000, 0.0000000000),  App.Rotation(0.0000000000, 0.0000000000, 0.0000000000))
  point_1.MapReversed       = False
  point_1.Support           = [(wp_1,''), (line,'')]
  point_1.MapPathParameter  = 0.000000
  point_1.MapMode           = 'ProximityPoint1'
  point_1.Visibility        = True
  points_1.append(point_1.Placement.Base)
  points[0].append(Draft.makePoint(point_1.Placement.Base.x, point_1.Placement.Base.y, point_1.Placement.Base.z, point_size=5))
  # - Create point on second working plane
  point_2 = body.newObject('PartDesign::Point', 'DatumPoint')
  point_2.AttachmentOffset  = App.Placement(App.Vector(0.0000000000, 0.0000000000, 0.0000000000),  App.Rotation(0.0000000000, 0.0000000000, 0.0000000000))
  point_2.MapReversed       = False
  point_2.Support           = [(wp_2,''), (line,'')]
  point_2.MapPathParameter  = 0.000000
  point_2.MapMode           = 'ProximityPoint1'
  point_2.Visibility        = True
  points_2.append(point_2.Placement.Base)
  points[1].append(Draft.makePoint(point_2.Placement.Base.x, point_2.Placement.Base.y, point_2.Placement.Base.z, point_size=5))
  # - Remove points
  doc.removeObject(point_1.Label)
  doc.removeObject(point_2.Label)
  doc.removeObject(line.Label)
obj = doc.addObject("Part::Feature", "Path_1")
obj.addProperty("App::PropertyVectorList", "Points")
obj.Points = points_1
obj = doc.addObject("Part::Feature", "Path_2")
obj.Points = points_2
obj = doc.addObject("Part::Compound","Projection_1")
obj.Links = points[0]
obj = doc.addObject("Part::Compound","Projection_2")
obj.Links = points[1]
#print (points_1)
#print (points_2)
doc.recompute()
hotwire.FCStd
(222.9 KiB) Downloaded 17 times
HardRock
Postby HardRock » Tue Feb 09, 2021 7:07 am
phpBB [video]
phpBB [video]
HardRock
Postby HardRock » Mon Mar 01, 2021 11:05 am
Learning to programm for FreeCAD :lol:
Here is a set of macro for creating GCODE for my 5-axis foam cutter.
Later it will be separate workbench. Have a lot ideas that want to implement.
Video of usage FreeCAD to generate GCODE. Video in Russian, but i think it does not need comments, all shown )
phpBB [video]
And first parts:
Image Image Image Image Image
