Coz we have FreeCAD and construction profile, this is not a problem
This machine will run under Grbl-Mega-5X with patches that I plan to do. GCODE generation software will be mine.
Hardware controller - MKS Gen 1.4 board.
Now all mechanical parts assembled. All axis running well without any backlash and locks. Also i have done test cut. Wire tensioner works well even on hot wire.
Next I need to screw controller board and power supply, and need to make "cable-management". Also table shoul be instaled, as well as acrylic case because cutter will have closed case and ventilation to make able usage at home.
As i said, GCODE generation will be made with new software, there are two variats:
1. Standalone generator
2. FreeCAD addon (workbench)
Second way is better in my opinion, but first much simpler for me because I'm not familar with FreeCAD internals and addon development.
I think i will ask some questions in development forum later.
