Exploded assembly
doul
Exploded assembly
Postby doul » Sun Feb 21, 2021 3:21 pm
Hello all !
FreeCAD can made assembly with several workbench like A2plus, Assembly 3 and Assembly 4, you can also explode them with the addon workbench Exploded Assembly, let's try it :)
First example : An welded assembly made with A2plus workbench
Peek 2021-02-21 13-09.gif (173.07 KiB) Viewed 717 times
arm3_a2plus_exploded_v1.FCStd
(54.54 KiB) Downloaded 11 times
Second example : an assembly made with workbenches : Sketcher, Part, SheetMetal & Fasteners. If a hole edge is selected Fasteners automatically place and sized up screws.
Peek 2021-02-21 14-04.gif (80.67 KiB) Viewed 717 times
plate.FCStd
(146.96 KiB) Downloaded 11 times
version FC0.1923964
FreeCAD is cool 8-)
Re: Exploded assembly
Postby chrisb » Sun Feb 21, 2021 4:28 pm
As your original post sounds as if all of this was done in A2plus: The model was assembled with A2plus. The explosion was made with addon workbench "Exploded Assembly".
doul
Postby doul » Sun Feb 21, 2021 5:53 pm
It wasn't clear, I'm so confused :oops:
First assembly is an A2plus assembly, second not, Fasteners workbench automatically place screws when a hole edge is selected.
Would I've to edit first post ?
FreeCAD is cool 8-)
Postby chrisb » Sun Feb 21, 2021 8:01 pm
You don't have to, you can if you want.
joachim520
Postby joachim520 » Tue Feb 23, 2021 2:00 pm
This will be helpful for an upcoming project of mine, thank you @doul :)
Joachim520
Freelance engineer
My website | Fiverr | YouTube
doul
Postby doul » Tue Feb 23, 2021 9:06 pm
Edited to clarity.
Rework of second example on post #1, added some colors, fixed placement and size nut mistake, correct bend radius for 10mm thickness and test of screw special group.
Peek 2021-02-23 19-30.gif (166.26 KiB) Viewed 359 times
plate.FCStd
(144.36 KiB) Downloaded 6 times
Cool ;)
FreeCAD is cool 8-)
