Grip Area Modeling
emills2
Grip Area Modeling
Postby emills2 » Fri Mar 12, 2021 9:51 am
i just saw the gorgeous https://forum.freecadweb.org/viewtopic.php?f=24&t=56225 post, and i couldn't help but notice the slight imperfection (subjective opinion) on the steering wheel grips, so i decided to fart around.
I think the result is neat, so decided to share. I think the technical aspects are somewhat interesting, even if the design itself is a bit exagerated and cartoonish.
Re: Grip Area Modeling
Postby chrisb » Fri Mar 12, 2021 10:09 am
Would you mind telling a bit about how you did it, which workbenches and tools you used?
emills2
Postby emills2 » Fri Mar 12, 2021 10:25 am
sure.
part>revolve the torus, part>extrude the cutout volume, part>boolean to remove the cutout.
sketcher workbench sketches(important) to capture the edges i want to match on the edges of the cutout.
Silk workbench to convert the captured edges to control points, create the fancy curves, create a control grid from the fancy curves and control points, and slap a smooth surface with G2 along the length and G1 across the new cross section (one quarter of the cutout).
multiple Part>mirror to copy the new surface and close the gap.
then Part>shell (collect surfaces), Part>offset (inward), Part>solid (on both shells), Part>extrude the mini texture cutout, draft>Polar_ array, Part>boolean cutout from outer solid only, Part>fillet along the texture cuts.
Part>Fillet is working REALLY nice. i hadn't tried it since the edge selection was improved. I was pretty impressed to be able to even just select all the edges shown below...and then it actually filleted them!
i haven't booleaned out the inside section from the outside section. that just takes time and doesn't affect the test i wanted to do.
Postby chrisb » Fri Mar 12, 2021 10:55 am
Thanks for reporting back. It's apparently far from trivial.
emills2
Postby emills2 » Fri Mar 12, 2021 11:03 am
Well, all the Part workbench stuff goes really fast. The tricky part is deciding which topology to use with Silk. This is usually the case with these models. It takes a little bit of head scratching to set it all up, but it ends up at the minimum necessary complexity. Actually it just fails if you try to make it too complicated. But once you have it set up, it is incredibly rewarding and addictive.
check out this live editing animation:
https://github.com/edwardvmills/Silk/bl ... _01_01.gif
the feeling is pretty awesome once you can fine tune your objects like this. i'm not sure you can buy this feeling anywhere :)
tom_hampton
Postby tom_hampton » Wed Mar 17, 2021 1:22 pm
Hey, thanks for the compliments. You're right about the imperfections. I couldn't really figure a good way to model the grips. I settled on a pad of the Z-down view, then a revolved "groove" to get the profile close, and then some big fillets to blend the remaining rough edges.
For what I was doing that was good enough for visualizing the space between the grip and the button plate. They don't show up too much in FreeCad, but they do stand out in any Povray renderings.
You're approach looks fantastic. Heck, I didn't even know about the Silk workbench! The revolved groove above is about the fanciest thing I've done.
emills2
Postby emills2 » Thu Mar 18, 2021 12:50 am
The tesselated look in povray turns out really nice for regular objects, but for your revolve-grooved and filleted extrusion, you could lower the object's angular deviation and deflection tolerances in the view properties (before you export to povray). You could also do the whole model at higher surface resolution, but it has a nice feel as is for most objects.
tom_hampton
Postby tom_hampton » Fri Mar 26, 2021 7:46 pm
Thanks for that. I knew there had to be a way. Reset to:
Angular Def: 5*
Deviation: 0.1
FreeCAD:
POVRAY:
