Stern driven paddle steamer engine
un1corn
Postby un1corn » Fri Mar 19, 2021 3:34 pm
A 2 cylinder steam engine driving a stern drive paddle steamer.
Plans by Julius de WAAL on http://www.vapeuretmodelesavapeur.com
The length of the reversing shaft (red) and any additional support would be determined by the builder to suit the application.
My first attempt on V 0.19.
SD 7.JPG (320.07 KiB) Viewed 1397 times
SD 6.JPG (361.63 KiB) Viewed 1397 times
SD 1.JPG (409.45 KiB) Viewed 1397 times
ppemawm
Re: Stern driven paddle steamer engine
Postby ppemawm » Thu Mar 25, 2021 2:53 pm
un1corn wrote: Fri Mar 19, 2021 3:34 pm My first attempt on V 0.19.
And, a successful one at that! Another beautiful un1corn model.
The detail and precision you include in your models are always fascinating.
Thanks for sharing.
Some questions:
Are you using Part Design and A2Plus assembly workbench?
Any V0.19 problems that you did not have with the earlier versions?
Ever thought about trying to animate an assembly like this?
un1corn
Postby un1corn » Fri Mar 26, 2021 4:57 pm
Thank you ppemawm for your comments.
Yes, I am using Part Design and Assembly Workbench A2plus V4.04.
I did have some problems using V0.19 Some things do not work as expected, I put it down to my inexperience of V0.19 and the fact it is not a stable version, so I am continuing with V0.18 until the wrinkles are smoothed out.
