Earbuds model with approximation
MrCAD
Postby MrCAD » Sun Mar 28, 2021 12:20 pm
Modeling of my own Realme Earbuds in FreeCAD 0.19.
Three workbench used back-to-back; Curves WB, Part WB, and Surface WB.
Faced difficulties / problems:
1) The blue colored body cannot UNION with rest of the model, neither in Part WB nor in PartDesign WB.
2) Won't able to make earpiece after making a solid body of all surface used in Curves WB.
Suggestions:
Let me know if anybody would figure out how to boolean two different body which is made with other than PartDesign WB.
I made two model for modeling of Earpiece (semi transparent soft fabric in Black color), because of the problem faced mentioned above (second).
Final Ear Buds.FCStd
(63.21 KiB) Downloaded 5 times
EarBuds.FCStd
(183.18 KiB) Downloaded 6 times
OS: Windows 10 Version 1909
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/India (en_IN)
thschrader
Re: Earbuds model with approximation
Postby thschrader » Sun Mar 28, 2021 4:13 pm
you have inner faces in the earbud solid. I did this:
1. downgrade earbud-solid to individual faces with arch-wb.
2. eliminate faces 5+17, the inner ones.
3. curves-wb: make solid from remaining faces.
4. part-wb: fuse all bodies.
BTW: interesting project :)
Final Ear Buds_ts.FCStd
(254.19 KiB) Downloaded 3 times
MrCAD
Postby MrCAD » Mon Mar 29, 2021 8:56 am
Good to know that you used Arch-Wb for this purpose, which I wasn't aware about . I'll definitely give it a try in next project, thanks for the tips.
Thank you, will try more projects on surface designs like this one, which is my weakness in modeling.
freedman
Postby freedman » Tue Mar 30, 2021 5:53 am
How do you know if you have it right, you can hardly hold the darn things? Ya! good project.
