Fork, Spoon and Cup
Fork, Spoon and Cup
See my below screen caps from my part files.
I built a fork, a spoon, and a cup to sharpen my freecad skills.
Then I made a jet engine frame to see how freecad would do with a more complex part. It had some weirdness with fillets where they'd break surfaces into darkened many pieced surfaces, but I got around that by using multiple fillet tools.
To interact with the models in a web browser, check them out on my website:
http://justinablack.com/cad-modeling-freecad-tests/
- cup.png (22.19 KiB) Viewed 12272 times
- spoon.png (16.54 KiB) Viewed 12272 times
- fork.png (14.57 KiB) Viewed 12272 times
Re: Show your FreeCAD projects here!
Great work! How did you make the spoon?
The spoon was the hardest! I ended up making it with the following method:
part design revolve for the fwd part of the spoon that goes in your mouth. Then lofts to make the transition part back to the handle. Then extrudes and subtracts to make the handle. See my attached freecad spoon file:
I've also posted interactive model views on my website:
- 2014-01-05_spoon.FCStd
- (367.31 KiB) Downloaded 910 times
Nice! That's a bit of work on that spoon.spacether wrote:The spoon was the hardest! I ended up making it with the following method:
Mark
You got that right.
But I'm surprised the loft_planes_fixed intersection worked. AFAIK booleans are not supposed to work with non-solids.
I had solid turned on for that loft. So it was a solid to solid union.
And I don't think it worked in v13. I had to fire up some v14 build union it, then save the file.
The solid parameter is irrelevant since the loft_planes extrude is made of disjointed surfaces. Which should not be allowed for booleans, but it worked for you, so I won't argue further.
I'm impressed. Spacether makes more sophisticated things in FreeCAD than many people (including me) in the commercial CADs.
Yes, that spoon is a really complex object... spacether, would you mind if I use a screenshot of it on the showcase on the http://www.freecadweb.org page?
Yorik, I would be delighted. I'm glad one of my parts can help showcase FreeCAD.
