call for screenshots - By Yorik
yorik
Founder
Re: call for screenshots - By Yorik
Post by yorik »
OficineRobotica wrote: Wed Nov 24, 2021 4:44 pm It would be nice to habe it remember the dimension. Could you please do something about that?
Ok that should be easy to do, adding to my TODO list.
Not sure in linkstage3 modified something about Qt's WebEngine?
ifohancroft
Post by ifohancroft »
jimmihenry wrote: Wed Nov 24, 2021 1:28 am 200 steps per revolution outstanding repeatability. Used in applications like scanners, floppy drives, disk drives, CNC machinery and
most downloaded model on my GrabCAD. Yes it is a Stepper motor, precisely NEMA17 x 40mm about 45cm holding torque @ approximately
2 Amps. Here is the link to this model and some other NEMA17's.
Nema17 x 33mm: https://grabcad.com/library/nema17-x-33-1
Nema17 x 40mm: https://grabcad.com/library/nema17-x-40-1
Nema17 x 48mm: https://grabcad.com/library/nema17-x-48-1
Nema17 x 60mm: https://grabcad.com/library/nema17-x-60-1
Cheers.
Any chance you can share the source (FreeCAD) file for it? I'd love to see how you've made it. Specially the animation and the cables.
I like making, breaking and modding stuff, using a soldering iron, code or both. https://ifohancroft.com
jimmihenry
Post by jimmihenry »
ifohancroft wrote: Thu Nov 25, 2021 10:51 pm Any chance you can share the source (FreeCAD) file for it? I'd love to see how you've made it. Specially the animation and the cables.
The animation is made with Gimp, the images for the animation are made with a macro by Mario52 it is called SCREEN WIKI.
Here is the link for more information: https://wiki.freecadweb.org/Macro_Screen_Wiki. You can also use FreeCADs positioning
and the feature Save picture... (Tools -> Save picture...) to create the images, this is how i made the F22 animated GIF. The wiring
is made using several sketches, all with a simple circle. The sketches are raised to different heights and moved circular around the
Z- axis. To get the solid i used the Additive loft feature from the Part design workbench. You could do the cable using the Additive helix
feature. Make a sketch containing a circle and you are almost done. Everything here is the most simple procedure. I have added the
FreeCAD *.FCStd files to my GrabCAD page: https://grabcad.com/library/nema17-x-40-1
Helix & Loft.png (151.17 KiB) Viewed 9037 times
thomas-neemann
Post by thomas-neemann »
animation of a step file in freecad
https://www.youtube.com/watch?v=4462iOnY5A0
phpBB [video]
jimmihenry
My animation of a FreeCAD file in FreeCAD :lol:
phpBB [video]
It is my first try...
ifohancroft
jimmihenry wrote: Fri Nov 26, 2021 5:42 pm
Thank you so much!
jimmihenry
Hi, i would like to introduce the wire bridge. It is meant to bridge traces on PCB's. Made for KiCAD
including the symbol (*.sym), footprints (*.kicad_mod), 3D- Files (*.wrml) and (*.step). The native
3D (FreeCAD) file is also included. Get it here: https://grabcad.com/library/wirebridge-for-kicad-1
The length is driven by a spreadsheet, also the insulation. The provided footprints can be replaced
by thruholes/ pads. Vrml and step files can be generated using the KiCADStepUP workbench. To do
so follow the steps below:
1. Load the "Wirebridge_Native_3D.FCStd".
2. Switch to the "KiCADStepUp" tool workbench.
(You may have to download it, go to the "Main menu -> Tools -> Addon manager").
3. Click the Spreadsheet in the "Combo View Panel".
4. Set your desired length in cell "B3".
5. Click the Part (Yellow) in the "Combo View Panel".
6. Click the "ksu Make Compound" button from the KiCADStepUpTool menu.
7. Click the created "Wirebridge_sp" in the "Combo View Panel.
8. Click the "ksu Export 3D Model" button from the KiCADStepUpTool menu.
9. Follow the KiCADStepUpTool instructions.
:idea: My tip: To get the shiny copper you will have to manually customize the *.vrml file, take the files i
provided as an example and open them with a text editor. Otherwise the color will by matt like the *.step file.
Step does not provide specular colour. Specular colour makes the stuff go blink, kind of. Changing the colour
provided by the KiCADStepUp tool will also give you the shiny surface.
I hope you will find some use with the provided files and fun creating your own variants and importing them
into KiCAD library.
(Traces on the shown PCB are for good looks :lol:. They should be on the other side of the PCB for through hole
components, however if you are using a 3018CNC for isolation milling you may check the orientation...)
Bluetooth Volt Divider 640x480.png (99.62 KiB) Viewed 8560 times
weasel_face
Post by weasel_face »
Injection Mold
weasel_face : Marco Silveira
jimmihenry
Hi, here is a digital mock up of my 3018CNC i did mention. I made this 3D model for further improvement of the machine. The 3018 comes ready
for action, in my case for about 140$. Overall it is a toy capable of PCB manufacturing and engraving. Some wood and plexiglass milling is also
possible. The best is it runs GRBL, this is a firmware that makes a microcontroller to a CNC motion controller running G- code. Inkscape can put
out a 2D G- code, FreeCAD puts out a 3D G- code via the "Path Workbench" this means you can mill for example a lens or even a relief...
The level of detail you see here does not represent threads, the motor is also da dummy a place holder. Other parts have full level of detail.
The PCB shown in the image is so tiny it is not possible to solder by hand, the engraving bit has a diameter of 3mm. This was my first try.
Techliefer 3018CNC.png (161.79 KiB) Viewed 8075 times
PCB isolation milling 1024x768.jpg (210.84 KiB) Viewed 8075 times
Aleks
Post by Aleks »
weasel_face wrote: Thu Dec 02, 2021 3:09 pm Injection Mold
Can you show more of your injection mold? What does the injected part look like?
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
