Well here it is. A small gear for a servo. Now if I could only get it made in Delrin or Acetal.... cheap, and before Christmas.
plastic gear
plastic gear
- 24T 8T plastic gear.fcstd
- FreeCAD file
- (150.66 KiB) Downloaded 260 times
Re: Show your FreeCAD projects here!
Nice gear! Odd thing though, the Cut feature should normally have below it two solids, a big cylinder and a smaller one that cuts the first to create the hole; but it seems to have been lost.
Also, the bottom and top gear need to be fused with the cylinder to make it a single part.
As for having it made... I guess 3D printing would not be precise enough for the teeth? Plus I don't think Delrin and Acetal are available materials. And I believe CNC machining is expensive... Good luck!
@ logari81
It's a rare thing to see a programmer actually show that he actually uses the software to model stuff!
@ logari81
I fused it after that screen cap. It is one part now. It drives the worm gear in a Meade 492 Two Motor Drive System. They won't provide support for it and I can't find it normally stocked at a gear supplier. So I made this so I could send it out for estimates. My wife's uncle has one of these http://www.gemvision.com/html/products/ ... o540c.html and might be able to cast it in copper, but the bit has a 10% angle error and certain dimensions might not be right because of it. He can also use the file I made to try it.
