Hello Freecad Forum,
Some time ago I made a small wooden box with dovetails. Thought I would share... Happy to get comments on how one could improve on the design.
The box is made of ash and oak wood, with a plexiglass top and a red linoleum "floor". The Freecad drawing shows - as can be seen - the box in exploded view.
The box is handmade with dovetails made with handsaw and chisels. I am not totally satisfied with the result especially the dovetails (still learning...- therefore I am thinking of investing in a so called Woodrat, which is a kind of router rig, that can make perfect dovetails, among other things.
In fact, I made the Freecad drawing after I made the box in real life... but I am happy that I made the Freecad drawing in case I will make the box again in real life (possibly using the Woodrat routing jig)
Kindly, KFMadsen
PS. As I recall the dimensions are aprox. 25 cm x 15 cm rectangle and with a height around 6-7 cm (don't have the physical box where I am situated therefore the approximated numbers)
Wooden box with dovetails
- boks.jpg (310.37 KiB) Viewed 4277 times
- Eksploderet version af boks.jpg (100.09 KiB) Viewed 4277 times
Re: Wooden box with dovetails
Nice work, thanks for sharing!
Looks great !
Great to see a nice woodworking project made in freecad. Did you make it in part design or part workbench?
Nice, are you going to share the FreeCAD file too? What did you apply to the wood to protect it?
Regards / Viele Grüße
Max
Max
