Filament spool holder with part workbench
Tek3D
Post by Tek3D »
phpBB [video]
Download files: https://www.thingiverse.com/thing:4881187
Tek3D
Re: Filament spool holder with part workbench
Post by Tek3D »
Not sure if the insert video function worked, so here's the direct link: https://youtu.be/T4A17KOzd_8
I appreciate that you uploaded the FreeCAD file and not only the mesh to thingiverse.
Tek3D
Post by Tek3D »
chrisb wrote: Tue Jun 08, 2021 6:14 pm I appreciate that you uploaded the FreeCAD file and not only the mesh to thingiverse.
No problem! I tried to upload it here, but it said it's too big.
Mikeosaurus
Post by Mikeosaurus »
Nice!
Rod ordered, already have those bearings, printer printing :)
Now... do I need to print this... then fit it, then print it again with the extra quality it'll give me? :lol:
Tek3D
Post by Tek3D »
Mikeosaurus wrote: Sat Jun 19, 2021 2:50 pm Now... do I need to print this... then fit it, then print it again with the extra quality it'll give me?
Haha, if you get a few unexplained blobs, then maybe. I could hear my old spool holder bind up and jump from the other room on a couple of occasions.
Mikeosaurus
Tek3D wrote: Sat Jun 19, 2021 3:21 pm
Even now printing, it's like clicky clicky clicky as the spindle turns... This might be the best printed upgrade out there... as I've evidently got the filament feeding in a twitchy way.
Definite upgrade from using an old toilet roll tube 8-)
Tek3D
Post by Tek3D »
Just putting the spool next to printer solves the problem as well, but I didn't want to do that to save space. I like it up top and out of the way.
Mikeosaurus
Looks awesome... now I need to find something to get printing this weekend :).
Pretty hostile comment on thingiverse from Stanley (might just be english not being first language), or that he's also got a bearing-based holder (with crazy text description... read the end for confusion!)... but I reckon this'll work just perfect. No more creaky twitchy feeding!
Will give it a try and see if there are any problems with unwinding. I wouldn't think it pulls so fast to be a problem, plus I have a feeder arm, so some slack for retraction should be taken up in that bit.
Now I just need to find an 8mm M5 for it :)
Tek3D
Post by Tek3D »
Mikeosaurus wrote: Fri Jun 25, 2021 3:54 pm Pretty hostile comment on thingiverse
Welcome to the internet, it happens :(
I did have an issue with a previous version that was completely free spinning, and it would randomly start unspooling. With this version I just snug up the collar to give it a bit of drag and it works fine.
I see there's barely enough room to use a bolt instead of a set screw, I didn't think about that, should've left more room. Are you able to get the spool nut over the bolt on the other side?
