Hello, FreeCAD community!
I am a new user as well as member in this forum. This is my first work with FreeCAD, using Sketcher workbench, drawing an 'M' letter. Finally I managed to do "Extrude" with FreeCAD.
First Time Drawing with FreeCAD
- 3D design, Part Design workbench
- Screenshot from 2021-07-23 22-12-20.png (171.34 KiB) Viewed 3399 times
- 2D design, Sketcher workbench
- Screenshot from 2021-07-23 22-05-27.png (182.29 KiB) Viewed 3399 times
- Shalmeneser
Re: First Time Drawing with FreeCAD
1st time is always 1st time.
Std_ViewScreenShot
Std_ViewScreenShot
- Shalmeneser
Next step : do not use the grid and set dimensions.
- M.FCStd
- (24.47 KiB) Downloaded 56 times
Hello, forum friend! Thank you very much for your quick reply and guidance. Wow, I got an example it helps a lot.
Under 1 hour, I can finish my own name 'MALSASA' with Part Design workbench. Amazing experience to me! I attached my FCStd file along with this message.
PS: I am an avid Inkscape user who long time ago was used to Sketchup's way of extruding.
- malsasa.FCStd
- (65.99 KiB) Downloaded 54 times
- MALSASA, created with Part Design workbench
- Screenshot from 2021-07-23 23-31-30.png (180.53 KiB) Viewed 3348 times
- Shalmeneser
File > Import > .svg
Draft_Draft2Sketch
Part_Extrude (for multiple bodies) or PartDesign_Pad (unique body)
Thank you very much for this valuable clue! I will try, my Friend.Shalmeneser wrote: ↑Fri Jul 23, 2021 5:03 pm
Draft_Draft2Sketch
Another tip: Design your model centered to the coordinate system if you don't have a reason not to. This is going to make things like mirror much easier to use.
Regards / Viele Grüße
Max
Max
btw when drawing lines and curves for letters the constraint system is superb !
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
