From construction to real part (e-guitar humbucker holder)
Nanayaw
Post by Nanayaw »
Hello All
at my e-guitar the two humbucker holders are cracked into parts cause of less quality of plastic and design.
Starting point >>> two holders with different dimensions
Small Holder
Big Holder
After printing following I have to rework at the part
> The holes are small but screws could set
> The countour I set at the big holder wasn't the same as at the guitar so I
grinded a bid and then it was okay.
Acc. the construction because I'm not experianced well in the workflow
so that it is not complete parametric, but if somebody need holders like
that maybe it could be helpfull.
Results
Greetings
Nanayaw
Big_Holder-2-D.FCStd
(42.47 KiB) Downloaded 102 times
Small_Holder_Final.FCStd
(298 KiB) Downloaded 94 times
Small_Holder_2-D.FCStd
(19.05 KiB) Downloaded 91 times
Holder_small.stl
(758.19 KiB) Downloaded 97 times
Holder_big.stl.zip
(463.34 KiB) Downloaded 93 times
Nanayaw
Re: From construction to real part (e-guitar humbucker holder)
Post by Nanayaw »
Here the next file
Big_Holder_Final.FCStd
(16.23 KiB) Downloaded 97 times
Nice project. Are you interested in some comments concerning your sketching?
Nanayaw
Post by Nanayaw »
Hello chrisb
there is not a lot to say I used a normal sketch and sketches based on date planes
I'm not well experianced, learning by doing.
Greetings
Nanayaw
M4x
Post by M4x »
Thank you very much for sharing your work here!
I think chrisb tried to offer you some tips to get better ;)
Shalmeneser
Post by Shalmeneser »
:idea:
guitar_SHALM.FCStd
(194.37 KiB) Downloaded 90 times
M4x wrote: Fri Sep 17, 2021 6:32 pm I think chrisb tried to offer you some tips to get better ;)
Indeed. Nanayaw, if you are interested, let me know, because I will have to reinvestigate your sketches. After all it's more than a month ago that I looked at them.
Nanayaw
Post by Nanayaw »
Hello chrisb
thank you very much for your offer, feel free I get it done and guitar works well :lol:
Shalmeneser your work looks more profesional as mine great job and thanks for sharing
Greetings
Nanayaw
So here are my comments, they may be educational for others:
- You should prefer geometric constraints over dimensions. As soon as dimensions are repeted it is a strong indicator for replacing one of them.
Your Sketch contains 42, of which are 25 dimensions:
- If you thoroughly choose the origin, you can simplify your sketch even further. If necessary adapt the Attachment or the AttachmentOffset to properly arrange it relative to some in the outer world. The sketch refactored has 25 constraints of which 9 are dimensions:
- Finally you should consider to model only 1/4 and then use a pattern / multipattern on the feature using the sketch
Nanayaw
Post by Nanayaw »
Hello chrisb
Thanks for your great explaintation
Could you please share the sketch then it will be easier to analyse
Thanks and Greetings
Nanayaw
