From construction to real part (e-guitar humbucker holder)
Hello All
at my e-guitar the two humbucker holders are cracked into parts cause of less quality of plastic and design.
Starting point >>> two holders with different dimensions
Small Holder
Big Holder
After printing following I have to rework at the part
> The holes are small but screws could set
> The countour I set at the big holder wasn't the same as at the guitar so I
grinded a bid and then it was okay.
Acc. the construction because I'm not experianced well in the workflow
so that it is not complete parametric, but if somebody need holders like
that maybe it could be helpfull.
Results
Greetings
Nanayaw
Small Holder
Big Holder
Results
Greetings
Nanayaw
- Big_Holder-2-D.FCStd
- (42.47 KiB) Downloaded 102 times
- Small_Holder_Final.FCStd
- (298 KiB) Downloaded 92 times
- Small_Holder_2-D.FCStd
- (19.05 KiB) Downloaded 90 times
- Holder_small.stl
- (758.19 KiB) Downloaded 96 times
- Holder_big.stl.zip
- (463.34 KiB) Downloaded 92 times
Re: From construction to real part (e-guitar humbucker holder)
Here the next file
- Big_Holder_Final.FCStd
- (16.23 KiB) Downloaded 97 times
Nice project. Are you interested in some comments concerning your sketching?
Hello chrisb
there is not a lot to say I used a normal sketch and sketches based on date planes
I'm not well experianced, learning by doing.
Greetings
Nanayaw
Greetings
Nanayaw
Thank you very much for sharing your work here!
I think chrisb tried to offer you some tips to get better
Regards / Viele Grüße
Max
Max
- Shalmeneser
- guitar_SHALM.FCStd
- (194.37 KiB) Downloaded 89 times
Indeed. Nanayaw, if you are interested, let me know, because I will have to reinvestigate your sketches. After all it's more than a month ago that I looked at them.
Hello chrisb
thank you very much for your offer, feel free I get it done and guitar works well
Shalmeneser your work looks more profesional as mine great job and thanks for sharing
Greetings
Nanayaw
Greetings
Nanayaw
So here are my comments, they may be educational for others:
- You should prefer geometric constraints over dimensions. As soon as dimensions are repeted it is a strong indicator for replacing one of them.
Your Sketch contains 42, of which are 25 dimensions:
- If you thoroughly choose the origin, you can simplify your sketch even further. If necessary adapt the Attachment or the AttachmentOffset to properly arrange it relative to some in the outer world. The sketch refactored has 25 constraints of which 9 are dimensions: - Finally you should consider to model only 1/4 and then use a pattern / multipattern on the feature using the sketch
Hello chrisb
Thanks for your great explaintation
Could you please share the sketch then it will be easier to analyse
Thanks and Greetings
Nanayaw
Nanayaw
