FreeCAD is awesome. I don't post very often but this one took some tinkering and maybe this will help the next person:
1) Trying to make a solid disk and using Part Design boolean cut for each hole will take a long time.
2) Didn't know that Daft downgrade will work on arrays so that individual items could be deleted.
3) Didn't know that Draft > Draft to Sketch works backwards in case corrections need to be made to the sketch
4) Forgot about "record macro". Recording a macro when a extruding a sketch in Part workbench shows how to make a script to do this.
I ran this on a Dell Latidue 5410 with an I5 @ 1.7 GHz and it takes about about 5 minutes to:
1) Read in the coordinates
2) Draw all the circles using Draft.makeCircles
3) Make the sketch using Draft.make_sketch
4) Extruding the sketch
OS: Windows 10 (10.0)
Version: 0.19.23141 (Git)
Hash: 0eba78d40096720f7a637a9a73c382a08b820bca
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Tube Sheet - plate with 9,000 holes
- sample.JPG (204.73 KiB) Viewed 5595 times
Re: Tube Sheet - plate with 9,000 holes
Are you aware of Lattice2_Workbench / https://github.com/DeepSOIC/Lattice2?
Regards / Viele Grüße
Max
Max
Thanks for sharing!
Suggestions: Draft downgrade is not parametric. Another possibility should be a Link Array, where you can set ExpandArray=True. You can then access individual Elements of the array. I could move the unwanted elements out of sight, but I was not able to deactivate them. Does anyone else know how to do that?
No I did not consider Lattice2 - but I will and see how that works.
I disagree that Draft is not parametric, because that is exactly what I did to to build this.
I had two concerns with this problem:
1) Can FreeCAD handle this in a reasonable amount of time? And yes it can!
2) How to make this object - for which I have some additional comments
The Draft array of circles has to be downgraded twice, the first time it gets downgraded to a compound, the second time, the compund gets downgraded to faces, and these faces can be be selected and then "draft to Sketch" something along this:
objs = FreeCAD.ActiveDocument.Objects #assuming all the circles are to be in the sketch, if not a routine to select desired elements would be req'd
Draft.make_sketch(objs, autoconstraints=False, addTo=None, delete=True, name="tsht", radiusPrecision=-1)
doc.recompute()
Selecting 9,000 elements manually like "select all" takes a while and is easy to lose them when "draft to sketch" is selected
Using the "delete=true" above deletes the individual faces.
Thank you for your comments
doc.recompute()
How did you do that nice tube sheet?
I'm struggling with it for a while. I'm new with this whole CAD scene.
Could you show me some tutorial to get this done?
(I'm an NDT guy, I have a lot of tubesheet to test. I just get a drawing but that is always filled with another text and to book the welding defects would be difficult..)
Thank you all.
Thank you all.
Hit the tutorials and ask some questions in the Help section. These are fairly easy to model because you can work off of a standard XY plane. It looks like the only issue to learn about is how to trim away some holes.
