Centrifugal Pump components for experimental validation of numerical results.
The starting point was the fluid zone of the pump.
- fluidZone.PNG (104.57 KiB) Viewed 8125 times
FreeCAD was used to create the solid parts around the fluid:
- The volute casing in two parts, sent for CNC Machining made from aluminium blocks.
- The impeller, 3D printed
- Shaft nut and shaft sleeve, also CNC machined from aluminium.
- FreeCAD_solids.png (210.28 KiB) Viewed 8125 times
The parts were to be mounted on an existing pump (shaft, motor...).
Here it is half-mounted to see inside:
- pump_open_after_testing.jpg (94.61 KiB) Viewed 8125 times
And the test bench fully mounted:
- pump_mounted.JPG (174.1 KiB) Viewed 8125 times
My Techdraw drawings are way too horrible for me to show
Part and PartDesign Workbenches used all the way, with ''initial bodies'' used in PartDesign, where I had to learn the hard way that you do not sketch on an existing face, it
will break later.
