From FreeCAD To The Real World
Re: From FreeCAD To The Real World
3D printing looks great
Just wondering what is the purpose of the component in a window.
- ragohix769
It's to block the external darkening shutter (not the windows, the external, in Italy it's named "Persiana"). The original it's iron, but I've created the same, with a better shape and pretty solid (100% infill of course), in very basic PLA
This was my first time ever using Part Design, very cool and fun!
- wepz.jpg (116.65 KiB) Viewed 3820 times
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
I see, thanks
Looks good. I was just looking for something similar for my back door. What to print it on my Creality Ender 3. The model looks pretty simple.ragohix769 wrote: ↑Wed May 04, 2022 3:57 pm My real world stuff made with our loved FreeCAD:
Iron block system for my darkening shutter (outside the window) is broken. Easy redraw from scratch in Part Design with @FreeCADNews
and then printed. Thanks #FreeCad #opensource #community #foss
- ragohix769
Here you have my project file, if you want to modify it, very very simple Part Design jobJaffH wrote: ↑Fri May 06, 2022 7:29 amLooks good. I was just looking for something similar for my back door. What to print it on my Creality Ender 3. The model looks pretty simple.ragohix769 wrote: ↑Wed May 04, 2022 3:57 pm My real world stuff made with our loved FreeCAD:
- fermafinestra_mio_part_Design_007.FCStd
- (96.18 KiB) Downloaded 76 times
Great project: modeled, printed, done.
Some comments:
- I would have made all sketches fully constrained, because I usually have to readjust things after a first prototype.
- Choosing the origin so that you can benefit from symmetry, even modeling only half and doing a mirror is possible.
- Using the Hole feature saves one feature/dressup and makes you less dependent on topology.
- The simple copy seems superflous to me.
Some comments:
- Shalmeneser
- fermafinestra_mio_part_Design_007_SHALM.FCStd
- (66.43 KiB) Downloaded 81 times
- Capture d’écran 2022-05-06 185156.jpg (77.57 KiB) Viewed 3431 times
- ragohix769
Thanks Chris
1) That's right. It was fully constrained for the 3/4 of the time, but at the end I made some (big) modification from scratch, so the final body and sketches were not so clean.Some comments:
1 I would have made all sketches fully constrained, because I usually have to readjust things after a first prototype.
2 Choosing the origin so that you can benefit from symmetry, even modeling only half and doing a mirror is possible.
3 Using the Hole feature saves one feature/dressup and makes you less dependent on topology.
4 The simple copy seems superflous to me.
2) Mirroring was the first choice but I was not so capable (now I am ), I made a lot of other models design to finish this little micro project. In the beginning I used Part creating only boolean edit, it was very difficult. I never used Part Design logic, so this was my first time, it was fun, but I had problem understanding part design flow process, and that part it's not so compatibile with part design feature design. I can say that this micro-project was very useful to understand
3) I've seen this, because when I made some modification, a lot messed up quickly becuase this wasn't created with discipline. So when I was sure about measures, I quickly recreated all from scratch (we can say "rought").
4) simple copy was to experiment with rendering in mesh and to export, i've not saved that.
Thanks a lot for your suggestions
- ragohix769
Updated this microproject with mirror feature and fully constrained sketches
Thanks a lot to all for advices and suggestions
- fermafinestra_mio_part_Design__MIRROR_008.FCStd
- (43.18 KiB) Downloaded 72 times
- wepz_12.png (210.85 KiB) Viewed 3291 times
I just grinded a 120 grad spotting drill, using FreeCAD as help tool to figure out the angle needed to set on the grinder. Wonky geometry, but the drill bit works
- 120_grad_spotting_drill.jpg (112.4 KiB) Viewed 2866 times
