From FreeCAD To The Real World
cox
Re: From FreeCAD To The Real World
Postby cox » Fri Dec 04, 2015 9:51 pm
Wow, missing the smell of hot plastic just looking at this. Well done. :D
Cant wait for the update
+1 for video
A_3
Postby A_3 » Thu Jan 21, 2016 3:24 pm
Something simple, nozzle.
I apologize for the bad resolution оf photo, broken camera on a mobile.
Drawing is not done according to the rules, it shows only general dimensions...
Part is a test example for washing system, and the test was successful!
triplus
Postby triplus » Sat Jan 23, 2016 10:01 pm
Nice project.
P.S. CAD model, blueprint and an actual product.
JMG
Postby JMG » Wed Feb 03, 2016 9:58 pm
Hi.
I recently got access to a 3D printer (BQ Hephestos2) and today I printed two propellers to test the strength of the PLA.
Six blades propeller, intended for high rpm motors (+25k rpm), tested to 10k rpm only:
Two blade propeller that could suit the airplane where the test is performed:
The blade is designed as a loft over several sketches (sections).
Video:
https://www.youtube.com/watch?v=LSFR4in7vMg
Surprisingly, they withstand the rpms and the larger one even produces noticeable thrust :)
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
A_3
Postby A_3 » Wed Feb 03, 2016 10:28 pm
Great job!
By the way, excellent wind tunnel you have :)
DeepSOIC
Postby DeepSOIC » Mon Jan 30, 2017 9:48 pm
Recently I got myself a mini-lathe.
Milling attachments for it can be purchased, but they are a bit pricey. So I decided to make one with a bit of help from 3d printer.
This is the simplest model I've come up with. It allows me to re-use parts of lathe itself. The model is a creative process, so it's a total mess.
lathe mill stand (sectioned).png (94.94 KiB) Viewed 2878 times
mill stand v01b.FCStd
requires FC v0.17 and Lattice2
(66.94 KiB) Downloaded 40 times
Printed of PLA with 20% infill and 3 perimeters. It has just enough rigidity to slowly mill some steel. Not great, but good enough for occasional milling.
Thank you FreeCAD, Slic3r, Repetier-host and PrintBox3d :mrgreen:
Now I need a vise....
triplus
Postby triplus » Tue Jan 31, 2017 1:39 pm
Yeah sooner or later you are tempted to produce something you designed in FreeCAD!
rabbit
Postby rabbit » Sat Mar 18, 2017 1:43 pm
This is just a very simple thing: custom hooks to hang my self-made flyscreen frames when they're not in use.
The process, from having one topple over once again and realizing this can be solved to solution took probably about 30 minutes.
A_3
Postby A_3 » Tue Jun 13, 2017 7:19 pm
А simple sprinkler, 3D printed ABS plastic, for rear windscreen.
On the last picture you can see clean area, proof that the sprinkler works fine :D
bringThaRuckus
Postby bringThaRuckus » Tue Jul 18, 2017 1:36 am
The video is here - From FreeCAD To The Real World
I watched this video, I love the actual printer. What model are you printing with?! I haven't built a printer yet. I just found someone who will print the parts for me. can most of your printer parts be replicated? smartrap! gotta have one.
