Zombie project, or small conversion FC16->FC20
wieszak17
Post by wieszak17 »
I decided to reanimate a bit old project of mine - https://forum.freecadweb.org/viewtopic.php?f=24&t=5728 - it is Polish steam locomotive Ol49.
For now i will be converting files from FC16/FC17 to FC20 with some changes where new functionality will allow them. And when all files will be in new FC, then will be time to continue that revived project...
Project was put on hold when it was at that stage:
Progres for now:
main frame elements:
FC file: https://para.zonk.pl/Ol49forum/01/P202-1-0.fcstd
connectors between them:
FC file: https://para.zonk.pl/Ol49forum/01/P212-1-0.fcstd
FC file: https://para.zonk.pl/Ol49forum/01/8.18-01.fcstd
and pipes for steam exhaust
FC file: https://para.zonk.pl/Ol49forum/01/P672-1-0.fcstd
Will see how far i will progress with that...
bambuko
Re: Zombie project, or small conversion FC16->FC20
Post by bambuko »
Will follow with interest - hope you manage to get it going again ;)
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
KurtF
Post by KurtF »
Awesome! I just looked at your first sketch (frame)... how many hours did it take to put all this together? I'm thinking wow hours.
To get it we must want it. To keep it we must give it away. To give it away we must truly get it.
wieszak17
Post by wieszak17 »
KurtF: Not that much, it is rather simple job, you just need some patience to do it. I think it was about hour.
Next parts (unfortunately i usually do not know proper english names for them...):
-some parts are very simple, here are handrails on front bumper:
https://para.zonk.pl/Ol49forum/fcstd/02/9.11-0-1.fcstd
-part of connector locomotive-tender:
https://para.zonk.pl/Ol49forum/fcstd/02/10.04-0-2.fcstd
-guide for front coupler:
https://para.zonk.pl/Ol49forum/fcstd/02/10.20-0.fcstd
-another connector between frames:
https://para.zonk.pl/Ol49forum/fcstd/02/P213-1-0.fcstd
-support for boiler:
https://para.zonk.pl/Ol49forum/fcstd/02/P215-1-0.fcstd
-doors for smokebox:
https://para.zonk.pl/Ol49forum/fcstd/06/P663-1-0.fcstd
-joint/nut for regulation in steam engine:
https://para.zonk.pl/Ol49forum/fcstd/05/21.11.fcstd
-and something bit more complicated - wooden floor in cab:
https://para.zonk.pl/Ol49forum/fcstd/04/P410-1-0.fcstd
bambuko
Post by bambuko »
BTW why Ol49 ? why not something sexy like Pt47 :mrgreen: ;)
and just to prove that I am not prejudiced ;)
wieszak17
Post by wieszak17 »
Bambuko: more complete source drawings. There is still no tender drawings for Pt47 - I could use 27D51 tender (from Ty51), but I didn't want to trace all changes made to 33D47 (tender for Pt47) when it was adapted to Ty51.
bambuko
Post by bambuko »
wieszak17 wrote: Sat May 28, 2022 4:09 pm ...There is still no tender drawings for Pt47...
Thank you for the explanation - I have missed the lack of tender drawings :oops:
wieszak17
Post by wieszak17 »
Ok, six next parts:
-support for cab's floor:
https://para.zonk.pl/Ol49forum/fcstd/02/P218-1-0.fcstd
-front bumper:
https://para.zonk.pl/Ol49forum/fcstd/02/P220-1-0.fcstd
-boiler support: (here I was unable to recreate one of fillets, i don't know if this is regression or part need to be more redesigned)
https://para.zonk.pl/Ol49forum/fcstd/02/P221-1-0.fcstd
-clamps for boiler support:
https://para.zonk.pl/Ol49forum/fcstd/02/P222-1-0.fcstd
-side walking boards support:
https://para.zonk.pl/Ol49forum/fcstd/02/P223-1-0.fcstd
-connector between frames also support for breaking cylinder
https://para.zonk.pl/Ol49forum/fcstd/02/P224-1-0.fcstd
And first assembly try - it starting to take shape. Todays parts are colored.
bambuko
Post by bambuko »
What are you using for assembly?
I am looking forward to fully animated motion ;)
I also see that you are not using links in your models?
Is it because they are old v16 models?
wieszak17
Post by wieszak17 »
bambuko: Only Parts/Parts Design workbenches are used. I just put part in correct position and that's all - in this project i think there is no need for any assembly workbench, it is recreation of something ready, not designing something new.
Files are newly created, only sketches and sometimes starting pads or revolves are copied from old file. There is practically no way to use old files otherwise - any attempt to convert them ends in mess, crash or both.
