3D Printer Parts
clintonsam75
3D Printer Parts
Postby clintonsam75 » Tue Jul 08, 2014 3:55 pm
I am new to FreeCAD and mechanical engineering in general, but I love it and have learned a lot. Too bad I couldn't have pursued engineering when I was younger. My life would have turned out completely different if I had been able to. Kids today have it so good. :-)
I've been slowly buying parts to build a 3D printer. Whenever I buy a part, I model it using FreeCAD and assemble the parts together using Blender. Maybe I'll learn how to use the assembly workbench in FreeCAD soon. I just learned how to use the sweep tool today.
Anyways, I decided that my contribution to the forum, at least to start, is to post each part I model for the 3D printer to this thread. Then, anyone can take those models and assemble their own 3D printer, easily trying out different build methods. I'll also post screenshots and rendered images of my 3D printer as it develops. Here are my most recent screenshot and rendering.
3d printer stage 3 rendered 1.png (130.64 KiB) Viewed 9014 times
3d printer stage 3 rendered 3.png (71.76 KiB) Viewed 9014 times
clintonsam75
Re: 3D Printer Parts
Postby clintonsam75 » Tue Jul 08, 2014 4:04 pm
6.5mm bearing pulley
6.5mm bearing pulley.png (9.19 KiB) Viewed 9009 times
6.5mm bearing pulley.stl
(50.18 KiB) Downloaded 227 times
6.5mm bearing pulley.FCStd
(39.6 KiB) Downloaded 219 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:07 pm
8mm linear bearing with flange
8mm linear bearing with flange.png (16.43 KiB) Viewed 9008 times
8mm linear bearing with flange.stl
(98.91 KiB) Downloaded 212 times
8mm linear bearing with flange.FCStd
(55.53 KiB) Downloaded 172 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:10 pm
8mm linear bearing with pillow block
8mm linear bearing with pillow block.png (12.76 KiB) Viewed 9007 times
8mm linear bearing with pillow block.stl
(99.2 KiB) Downloaded 156 times
8mm linear bearing with pillow block.FCStd
(19 KiB) Downloaded 169 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:13 pm
8mm linear bearing
8mm linear bearing.png (18.84 KiB) Viewed 9006 times
8mm linear bearing.stl
(57.21 KiB) Downloaded 147 times
8mm linear bearing.FCStd
(30.4 KiB) Downloaded 141 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:16 pm
8mm rod support with flange
8mm rod support with flange.png (11.3 KiB) Viewed 9004 times
8mm rod support with flange.stl
(32.31 KiB) Downloaded 142 times
8mm rod support with flange.FCStd
(31.79 KiB) Downloaded 142 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:19 pm
8mm rod support without flange
8mm rod support without flange.png (12.87 KiB) Viewed 9001 times
8mm rod support without flange.stl
(48.32 KiB) Downloaded 122 times
8mm rod support without flange.FCStd
(42.68 KiB) Downloaded 128 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:21 pm
8mm x 500mm steel rod
8mm x 500mm steel rod.png (7.82 KiB) Viewed 9000 times
8mm x 500mm steel rod.stl
(4.96 KiB) Downloaded 114 times
8mm x 500mm steel rod.FCStd
(5.43 KiB) Downloaded 107 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:24 pm
pillow block (without bearing)
pillow block (without bearing).png (9.54 KiB) Viewed 8998 times
pillow block.stl
(48.32 KiB) Downloaded 126 times
pillow block.FCStd
(49.42 KiB) Downloaded 135 times
clintonsam75
Postby clintonsam75 » Tue Jul 08, 2014 4:26 pm
screw 1
screw 1.png (9.3 KiB) Viewed 8997 times
screw 1.stl
(14.54 KiB) Downloaded 135 times
screw 1.FCStd
(12.04 KiB) Downloaded 115 times
